04-30-2009, 02:33 AM | #1 |
Up Date got my jtr269.45 today
They sent me both the jtr269.40 and the jtr269.45
Got my Blue threadlocker got my greese gun for swing arm Got mobil 1 Synthetic grease for the swing arm Says for Wheel Bearings, Chassis, suspension got my punch for chain got new dremel cutting attachment and metal cutter wheels for chain You thing the grease will be ok for the swing arm only thing i think lacking is the ring plyers for the clip in sprocket does the needle nose work ok i think the project will be saturday morning i tried to bring bike up three flights of step to my back porch didn't work |
04-30-2009, 04:34 AM | #2 |
Bench grinder and a small punch works just as good also.
I have all of soberday to satur up!! |
04-30-2009, 11:31 AM | #3 |
Angle grinder and punch, dremel and punch....you might already own a chain breaker...
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
04-30-2009, 11:54 AM | #4 |
Measure twice, cut once. I use a dremel, vise, and punch. Easy.
Do you plan on much off road climbing with the 40?
Happy to serve. |
04-30-2009, 06:40 PM | #5 |
In a pinch you could use a file, rusty nail and a rock.
04-30-2009, 08:34 PM | #6 |
i knew someone had been in my tool box,,,,, Bug
halls auto l coolster, modcycles, yanmar & zongshen, dealer fired roketa,lifan and jet moto and apollo quit me who's next |
04-30-2009, 10:06 PM | #7 |
Thanks for the loan, i'll get that stuff back ASAP
05-01-2009, 09:15 AM | #8 |
A pair of big snap ring pliers to remove the snap ring on the rear sprocket.
A helper might come in handy too. I purchase a chain breaker for about $15 someplace. The other methods work too, but the breaker makes it easy. Allen
05-01-2009, 10:14 AM | #9 |
My snap ring pliers wont quite open up far enough. Ues my needle nose pliers to remove the snap ring and put it back on.
05-01-2009, 10:35 AM | #10 |
Is there any concern with the sprocket being too small and rubbing the swingarm pad too hard?
17 and 40 give a ratio of 2.35. I hope you only drive flats.
Chinabikeless |
05-01-2009, 11:06 AM | #11 | |
Happy to serve. |
05-04-2009, 06:26 PM | #12 |
Changed order
Ok you guys got me scared so changed order to 269.45. I think you guys helped me make a better choice. TY
05-06-2009, 04:41 AM | #13 |
If you went from a 46 to a 45 you won't notice much difference. I went from a 46 to a 39, now 5th is just overdrive and it'll run 70 in 4th. I'm also having trans trouble (3rd gear noise) that could be attributed to the lower gear.
05-06-2009, 07:21 AM | #14 |
I could be wrong but i think he started with a 56.
05-06-2009, 02:00 PM | #15 |
yes i got 56 on it now
