Old 04-16-2009, 03:15 PM   #31
Danthalis   Danthalis is offline
Okay, decided to go with the pz30 for mine as well, just for grins lol
Was wondering if you could help me out by figuring out what jets to get for it, or where you got yours at (like the tried and true method of aftermarket tinkering) Thanks in advance
Old 06-11-2009, 11:04 PM   #32
daboostcreep   daboostcreep is offline
Ok....so I think I may have stumbled upon a big bore kit for these motors. The piston size would increase from 67mm to 75mm. I believe that would near or top 300cc.
I need to know what engine our water cooled motor is a clone of. Anyone know??????
My motor is stamped 163ML
Old 06-12-2009, 09:46 AM   #33
I believe it's a lifan clone. Which is kinda weird because they don't have vertical 250cc engines (that I can find anyways) But this looks pretty close. Maybe someone can verify the measurements on the print there..
http://www.hooperimports.com/product.aspx?pf_id=E2005M
After further web surfing I'm now convinced that these are actually 200cc engines... and man that makes me angry :x Can anyone confirm that they are or are not 250cc engines? Thanks
Vbike V4-SW 250cc
Old 06-12-2009, 08:32 PM   #34
Well I was looking all over for specs...All I find for these motors is 200CC when I type 163ML.
I did read the manual and for specs it shows a bore x stroke of 78mm X 61.2mm. It also says the compression ratio is 8.9:1 which is very low. The manual also says the engine is 239ml. The front tag on the ATV says 230cc, the book says 250!
Please someone help. I need to know exactly whats up.
Old 06-13-2009, 02:30 PM   #35
katoranger's Avatar
When I put those numbers into a displacement calc it gives me 292cc.
Allen
Old 06-13-2009, 11:44 PM   #36
Allen
I ran the same calculator. I really don't get it now.
Old 06-16-2009, 12:24 AM   #37
anyone have some info?
