Old 03-17-2010, 10:58 PM   #31
Wild_Alaskan   Wild_Alaskan is offline
Wild_Alaskan's Avatar
jeez that seems pretty steep i got an axel and speedo hub for about $35 shipped for my gy-5. only catch was i was sent the wrong model :x
Dune buggy build http://chinariders.net/modules.php?n...wtopic&t=14470
400cc lifan build vid: http://youtu.be/20HoU8OK_Y0
other fun: http://tinyurl.com/wildalaskan
Old 03-17-2010, 11:11 PM   #32
Originally Posted by MICRider
Originally Posted by FastDoc
How much for the speedo drive?
$57 USD, the part is actually $40 but the rest is shipping and taxes. I would burn at least half of that in gas going back and forth, so it's not that bad
For $99, delivered (in the U.S.), you can get a Trail Tech Vapor computer for your motorcycle.
http://trailtech.net/vapor.html
The Vapor computer has a digital speedometer, odometer, tachometer, engine temperature gauge, and clock. I have been seriously considering getting a Vapor computer for my Zong, but my stock speedometer is pretty rugged, and works well.
Old 03-17-2010, 11:20 PM   #33
Yup, not a bad deal! If the speedo gives me any grief after I replace the drive hub, I will be going the digital route... I love all the different things that they do! (plus a trip meter for gassing up)
Old 03-17-2010, 11:27 PM   #34
If it's not too late, perhaps you can cancel your order for the speedometer, and get a Trail Tech Vapor? Then you can have all the features you want, and you won't have to worry about the stock, mechanical parts failing in the future.
Old 03-17-2010, 11:31 PM   #35
TheRealWorld   TheRealWorld is offline
I hope I did not miss this, but has anyone wired one up and if so how hard was it.
Old 03-17-2010, 11:36 PM   #36
Alas, the money has already been sent and I believe the part was shipped this morning . I hadn't seen the Vapor that you posted before, only the Veypor's (which are a lot more expensive!) I am just hoping the hub gives me a reliable speedo again. I will be happy at that
Edit: Oops, just realized I hijacked the heck out of your thread. Sorry Alan566...
Old 03-18-2010, 10:33 PM   #37
alan566   alan566 is offline
oh thats fine, highjack away!
Old 03-19-2010, 05:24 AM   #38
Alan, I just discovered the Zong can employ a JTR 471, rear sprocket with 50 teeth! Therefore, I recommend you switch to this rear sprocket.
Since you ride primarily on the street, you might want to keep your stock, 15T, countershaft sprocket combined with the larger, 50T, JTR 471, rear sprocket. However, the Yamaha TW200 employs a stock 14T/50T sprocket combination that is best for dual sport riding. I think you might be happiest with the 14T/50T sprocket combination.
Old 03-19-2010, 08:46 AM   #39
Cal25   Cal25 is offline
At the risk of hijacking, here is a good post with photos on an installation.
http://www.chinariders.net/modules.p...ighlight=vapor
I have one on my bike and like it.
Old 03-19-2010, 11:00 PM   #40
Spud, where can i find one of those sprockets at?
Old 03-19-2010, 11:23 PM   #41
You can find the information on the second page of the following thread, Alan.
http://chinariders.net/modules.php?n...r=asc&start=15
