Old 05-18-2010, 11:16 AM   #1
AceCombat   AceCombat is offline
Just dump the oil and gas drain the carb also pour a little oil down the spark plug hole and pull it over a few times if you don't plan on working on it for a bit this will keep the rusties from getting your rings and cylinder walls. As for the rest try to get it to somewhere dry that's heated. Should be okay. remember these are power toys and they can take a bit of abuse.
