10-22-2010, 09:33 AM | #31 | ||
Your right because black and orange is Fram. I'm confused because I can't find a Fram 131 but can find a K&N 131 online. Checking with the local bike shops this morning as soon as it warms up outside. |
10-22-2010, 10:02 AM | #32 | ||
Thanks for the link. Good info for me.That's where I was thinking about mounting a center stand. I wonder if the guy from China made any to sell? |
10-22-2010, 10:42 AM | #33 | |
BTW Suzuki oil filter # is 16510-05240. Any brand compitable w/ this will fit. |
10-22-2010, 11:41 AM | #34 | |||
That's what I thought, but I was intrigued by Barnone's XT225 observation. I thought that maybe a new China Bike flavour had emerged.
10-22-2010, 12:24 PM | #35 | |||
Happy to serve. |
10-22-2010, 04:01 PM | #36 |
It's actually a Hi-Flo 131 that is needed. But both the HF 131 and the
KN 131 are the same. They even have the same color. |
10-22-2010, 05:58 PM | #37 |
FastDoc and David,
Thanks for the replies. I stopped by the local shop earlier today and he happened to be out of the HF131 but he ordered some so I should be good to go. I used one the bolts from the crate to make a "tool" to fit the front axle on the allen wrench side to add to the tools. Just a couple of 12mm nuts locked together. From my ride today. 150km and took one gallon so that's WOW 93 MPG! Might have to check that again. I am trying to keep it under 4K RPM for the break in. Old Stewart Cabin I passed on my long ride up a gravel road. One lane bridge on my ride. Fall colors are peaking. Back home at our log cabin in Skeekah Cove just outside of Robbinsville,NC. |
10-22-2010, 06:09 PM | #38 |
I tried the same tool trick, it did not work for me, the axle was pretty tight. I bought some like large socket Allens and that's been no problem since then.
Happy to serve. |
10-22-2010, 06:14 PM | #39 |
Great ride. Beautiful country. You are especially blessed. You mileage does not surprise me at all. Expect it to improve after the motor is broken in.
Q Link's break in procedure, IMHO, is absurdly conservative. I used Suzuki's procedeure. Identical engine, same assembly line, much easier and more realistic break in procedeure. See if you can download a Suzuki manual for the DR200SE, or even call and ask a Suzuki dealer. Q Link, again, as Suzuki, uses normal oil in their bikes. Change it per the manual. No rush.
Happy to serve. |
10-22-2010, 07:52 PM | #40 |
I think another member found the SM-Q speedo/odo to be very optimistic. You mileage may not be that good. Still anything above 65mpg for these little bikes is pretty good.
10-22-2010, 08:18 PM | #41 | |
I keep forgetting to take my GPS to check the speedometer and odometer. My SYM HD200 scooter reads high by ten percent in speed and distance. My XT225 is right on since I put a larger diameter tire on the front. I figure that the XF200 should do about the same MPG as my XT225 which is about 70MPG. |
10-22-2010, 08:25 PM | #42 | |
I'l check the Suzuki manual like you suggest. |
10-22-2010, 10:13 PM | #43 |
I also used that tool trick.
Your reality looks splendid my friend !!! Love and Peace!! |
10-22-2010, 10:30 PM | #44 |
Thanks for posting the nice photos, Barnone. I am glad you are enjoying your XF200; it's a great little motorcycle.
P.S. I don't know the resolution of your camera, but please feel free to post larger photos; we would love to see more of your beautiful part of the world. Spud
10-23-2010, 01:02 AM | #45 |
There are some discrepancies in the manuals….I have the service manual and it messes with me when I find the discrepancies. Because I always follow the manufacturers recommendation.
One is that the bike, at least mine does, has the recommended oil as 15W40 and that is on the EPA decal on the engine. Then the owners manual actually conflicts within it….I am not getting into it but basically what I’ve been doing or using is Yamaha lube 20W50 universal all purpose oil for all 4-stroke engines. I have a heated garage and the only reason not to use that oil would be if you plan to start the bike when it is frozen and since my garage is heated and I do not ride ever in under 50 degrees, I will not have any issues. That oil improved the shifting greatly. I change the oil every 600km….it will never hurt and it does not cost that much. As far as break-in I used the kick starter in acc mode and gave it two kick before turning the ignition switch to on….then using the electric start. I would say she is new and I do not want to startle her. Then let her fully warm and more importantly get pressure up, before ridding her. Up to 5000km and then shifting and that to make sure her rings seat right, not going over because the rest of the engine is not ready for the load. I would not be too conservative because cylinder wall glazing is also a concern. But I also stayed under 4k for 1st and 2nd and maybe 3rd, but not the higher gears they can and should be taken periodically to 5k. That’s my opinion on it, these people that take the bike to load on the first ride are asking for trouble and some actual do that. What is really important is that the bike gets to a certain load within the first 20 minutes of ridding. I actually rode at a crazy level of varying load in 10-15 minute intervals for the first 500km. Heat it up and cool it down…it is all expanding and contracting. I do not like taking the bike to higher rpm even now that it is worn in, its actually painfully uncomfortable but it does need it to some extent. I kind of know instinctively when to do that, like when it is cooler outside and the bike is fully warmed up, that being I have been ridding it for a while at lower speeds. Then I open it up to clear it out. Follow the manufacturers recommendation and contact Qlink to make sure you have your warranty registered, some of the bike have had engine failures….so it is best to make sure you are in the good 100%. I had the valve lashes checked at 2500km and also had diagnostics done, it checked out fine. That’s a good bike basically you can just ride it….I had some issues with the shifting and indicator and getting in and out of gear and that passed after 500km pretty typical for new bike. That tells you something about why not to push a new engine, it is actually wearing together. It would get stuck in a gear at a light so I would partly let out the clutch and gently push on the shift lever. Other manufactures use that engine BETA offered a 200cc bike called an Alp for a while….same engine and the price was way more then what we paid for ours! welcome to the club! |
