Old 03-09-2022, 01:48 PM   #16
Missouri plates also no go. I think State plate sizes are mostly uniform. TBR7 must have South America/SE Asia compatibility slots.
I encountered this issue after a few other problems with my son's TBR7 assembly/build. I will post photos and some details elsewhere, but...
-battery too tall by nearly half inch, had to cut the airbox and then duct tape to seal it back up
-no hole in the rear brake lever for the rear brake light switch spring
-luggage rack holes don't line up at all, and the black cylinders on the rack are way off, don't lay flat (off by ~1/2")- just can't mount it!
-the worst issue... rolled it out for a first test drive after fixing the battery mount issue and changing the oil, and the left foot peg broke off as if welded with silly putty. I haven't dealt with that yet. It is a pretty lengthy list for a new motorcycle. Discovering the license plate bracket thing just made me shake my head. Easy to fix, well, yes, but I agree with OP. Stupid!
I don't anticipate ANY new rack from the importer. Will have to drill, cut, tape...
BAD WELDS could be real bad problem if it affects the rest of the frame!
My son is pretty disgusted with these things. Me too frankly. My Bashan Storm had NO issues, no broken welds in a year, better front suspension.. BUT NO kill switch
And the Storm cost almost exactly the same $
Gee
Old 03-09-2022, 02:18 PM   #17
Nospark   Nospark is offline
Thumper, It sucks that your bike is exhibiting so many mfg flaws. Mine, with a build date of May 2021, has been going together very well. The only fitment issues I've discovered are the top of the foot brake arm returning against the foot starter mounting bolt instead of the adjustable brake arm stop. I can easily remove a little material from the top of the brake arm and create clearance so it rests against the stop screw as intended. Only other thing is that the rack or tail of the bike seems to lean a bit to one side. Probably looks fine after a couple beers. Other than that, things went together well. I wonder if these bikes are produced in more than one mfg plant? If so, maybe one plant has their s@#t together and the other is a cluster f#$%k? All fasteners on mine were tight, all spokes were tight, no missing hardware, etc. I did notice the valve cover bolts were way too tight. I have to assume somebody on the line got a new power tool for Chinese New year.
Old 03-18-2022, 12:08 AM   #18
Fish_Master   Fish_Master is offline
Yea Texas plates don’t fit on my tbr 7 either
Old 03-19-2022, 01:13 PM   #19
wally   wally is offline
I'm in FL, my hawk came with a metal bracket to allow you to have a larger plate mounted on the plastic fender. Which still didn't fit the FL plate. I just chopped and drilled that metal piece .
I also tried mounting the plate vertically (which according to my research is legal in FL) . It fit fine in the space, with the bottom resting on the little ledge, but would require drilling 2 holes in the plastic, and clearing out some of the plastic stiffening ribs on the back of the fender to get space for a nut.
Old 03-20-2022, 10:26 AM   #20
Mounting vertical looked like an option to me as well. Drilling holes through the plastic might bring down the collector value when you go to sell it at auction 25 years from now.
2021 TBR7D
17 front, 42 rear
PZ30 Clone
Milwaukee, WI
Old 03-24-2022, 11:16 AM   #21
Sport Rider's Avatar
Originally Posted by krat View Post
Congratulations everyone, we have gone two pages and twenty posts on a problem any ten year old would have solved in 2 minutes with a rock and a big nail.
it's more fun to complain or make fun of others who are complaining.
Old 03-24-2022, 11:33 AM   #22
TominMO   TominMO is offline
I wish to lodge an official complaint that krat is spoiling our fun with his common sense.
2021 Lifan Xpect--sold
2022 Lifan KPX
1972 Honda CT90--The Carrot
1969 Honda CT90--The Tomahto
Cheesy is the WDK (workplace drama king). Now retired. Nope, back in the saddle. Nope, finally retired.
Old 03-24-2022, 01:18 PM   #23
This really added a lot to the thread.
Old 03-24-2022, 02:11 PM   #24
I tried facing mine backwards but the still would not line. BTW, Tao Motors still hasn't responded with their suggested solution and technical drawing I requested.
2021 TBR7D
17 front, 42 rear
PZ30 Clone
Milwaukee, WI
Old 03-24-2022, 03:37 PM   #25
seconded. Where's Jerry when we need him.
Old 03-24-2022, 03:58 PM   #26
Been there, Done that. lol
Old 03-24-2022, 05:18 PM   #27
Propane 1   Propane 1 is offline
Plate holder problem
I will bet you wouldn't have that problem if it was a ktm
Old 03-24-2022, 07:16 PM   #28
TRUE! I always solve problems better when my wallet is completely empty
Old 03-24-2022, 11:28 PM   #29
So did this.
I recommend we start a flame war of completely pointless insults back and forth to extend this thread another few pages.
I'll start: Hey pal, who you calling fat?!
2022 Lifan KPX
Old 03-25-2022, 10:52 AM   #30
So did this.
You're wrong.
