Old 04-23-2015, 01:18 AM   #3061
G19Tony   G19Tony is offline
G19Tony's Avatar
The bike is registered and with new headlights
I got my title and registration. Thanks to Steve at CSC, for getting the new paperwork right out to me. I replaced the dim 35w headlight with a PIAA 55w H4 headlight. I was looking for a Sylvania, but nobody carried an H4 base, so I had to go to Cycle Gear, and they had what I was looking for. I also replaced the little marker light with a bigger LED I had in my scrounge box. It was an easy job to remove the headlight assembly.
Headlight while on the lift.
New marker light
Low Beam
Highbeam
Low Beam with LED aux lights
Honda CB300R ABS
Old 04-23-2015, 01:22 AM   #3062
Originally Posted by oldqwerty View Post
What is a ZS LED?...
Originally Posted by G19Tony View Post
Zongshen. I work in aviation. We abbreviate everything.
I ordered the updated, RX3 LED headlight from Taobao.
http://item.taobao.com/item.htm?id=37861433653
I'm hoping my Taobao agent will ship my order of parts next week. As soon as my order arrives, I plan to install the upgraded, LED headlight. In the meanwhile I will experiment with an H4 bulb in the stock RX3 headlight.
If enough space is available behind the RX3 headlight, one could also substitute an LED bulb for the incandescent bulb in the stock headlight, as I did with my Honda CRF250X.
http://chinariders.net/showthread.php?t=13947
Old 04-23-2015, 07:26 AM   #3063
Huck369   Huck369 is offline
Huck369's Avatar
A couple pics of mine after I rode it to work this morning...added a quick release JC Whitney Trunk to it....will add the crash bars and side bags after some break-in miles
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 04-23-2015, 08:05 AM   #3064
I got my title and registration. Thanks to Steve at CSC, for getting the new paperwork right out to me. I replaced the dim 35w headlight with a PIAA 55w H4 headlight. I was looking for a Sylvania, but nobody carried an H4 base, so I had to go to Cycle Gear, and they had what I was looking for. I also replaced the little marker light with a bigger LED I had in my scrounge box. It was an easy job to remove the headlight assembly...
Good work, Tony. I plan to do the same in the next few days. Then after my upgraded LED headlight arrives, I can compare the stock HS1 bulb and the H4 bulb to the Zongshen LED headlight.
Old 04-23-2015, 08:10 AM   #3065
Nice work, Huck.
I installed the stock trunk for my first excursion on the dirt. The stock trunk is easily removed with three bolts. I plan to attach the mount for my JC Whitney Travel trunk with the same three bolts. Then I can easily swap trunks whenever I like.
P.S. Your camera accurately captured the true color of the fastest, orange RX3.
Old 04-23-2015, 08:26 AM   #3066
As planned, I took my RX3 for a 131-mile ride to experience it's first excursion in the dirt. It was a cloudy day which threatened to rain, but I made it home without getting wet.
The day started out fairly warm, but I knew it would be colder when I was returning. Therefore, I was going to carry my heated jacket on the luggage rack with bungee cords. However, I decided to install the stock trunk instead. The stock trunk is very light, and is great for carrying extra jackets, rain gear, cameras, et cetera, in a secure, waterproof enclosure. My jacket, as well as my camera and extra batteries were easily accessible, and my jacket was much more secure inside the travel trunk, rather than being attached to the luggage rack with bungee cords.
The RX3 did a good job in the dirt. The bike was only limited in the dusty soil by the stock tires, which still performed adequately. The forks definitely need heavier oil for a stiffer rebound damping. I hope CSC will be stocking the upgraded forks, which feature rebound damping adjustment. In the meanwhile, I will be swapping the stock fork oil with ATF in the next few days.
If you want to view more photos from my excursion, you might enjoy reading my ride report at the following link.
http://www.chinariders.net/showthrea...354#post183354
Old 04-23-2015, 09:14 AM   #3067
It brings tears to me eyes, Spud! It is like the beginning of the GY-2 all over again! Can't wait to see what adventures the RX3 will bring you!!
Old 04-23-2015, 09:24 AM   #3068
Thank you, Culcune.
Old 04-23-2015, 11:11 AM   #3069
I agree, I loved following along with the upgrades and adventures of the orange Zong, the pics and ride reports are awesome . Another bike for the sig!
The RX3 is a great looking bike!
Old 04-23-2015, 11:11 AM   #3070
Stew! How are you? It's been a long time!
Old 04-23-2015, 11:14 AM   #3071
katflap   katflap is offline
katflap's Avatar
New marker light
Nice mod, I would like to do this one .
Knowing next to nothing about LED bulbs, do they chuck out a lot of heat .My headlight has nothing in this portion (Honley RX3) . A bit
concerned about things starting to melt
Old 04-23-2015, 11:20 AM   #3072
LED bulbs produce almost no heat at all. They're ideal in enclosures.
Old 04-23-2015, 11:36 AM   #3073
katflap's Avatar
Thanks, that's good news
Old 04-23-2015, 11:37 AM   #3074
ripcuda   ripcuda is offline
ripcuda's Avatar
Do the modern LED lights used for turn signal lamps cause fast blinking anymore? I remember having to put resistors in the circuit to normalize the flashing rate.
Cheers!
'20 TaoTao Hellcat 125 "grommet"
'04 Yamaha TTR-125LE
'00 Yamaha TTR-90
'07 Kinroad XT200GY Runmaster (sold)
'07 KMD GY6 150cc ATV (sold)
'07 Kangchao 250cc ATV Monster (sold)
Baja Moto DB-30 "Doodlebugs"(x3) (sold)
'06 Hi-Bird 200 parts bike (sold)
Old 04-23-2015, 11:48 AM   #3075
Cheers!
Yes, or no blinking. Resistors aren't the answer, because you're mimicking the current draw of a standard incandescent bulb, so there is no power savings. Many of us have installed LED lights to conserve power and be kind to the little charging system.
The answer is an LED-specific flasher. They're cheap and easy to find. I think Spud buys his from https://www.superbrightleds.com/ , but I bought mine from www.bikebandit.com
