#421 |
Some low res pics of my shade tree stainless welding. Had to cut the straight section behind the frame mount and make a new frame mount. Unfortunately, my joint had too big of a gap and I hit a burn through. Made a sloppy-poppy patch and while not pretty, it works. I ain’t going to be welding in maranello…
The RBX pipe was too long for my base model and the muffler is a bit wide. Still fighting a bit of tire rub. It does work for the engine temps and it’s not louder than the stocker, as the stock unit was loud. Best part is I can throw her back to stock in 10 minutes. First creek crossing and I rode home 15 miles oblivious to the vines wrapping the hub, guess I ain’t gonna be riding in Maranello either. Wish I went with the 40 or a 39 rear sprocket, the 42 is better but I wouldn’t mind a bit lower. |
#422 | |
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
#423 |
R&L carriers says Templar X will deliver aug 2nd. First 2 templars came from Texas, the X is coming from California
#424 |
So lucky! Impatiently waiting for them to post another refurb or new stock. Hoping maybe the next couple days.
#425 |
I set exhaust at ~0.006" and intake ~0.005"
Range that will work is more like 0.005 to 0.007" exhaust, and 0.004" to 0.006" intake. I use these values for the Storm as well. Unless I find beleievable authority, these gaps are not too narrow. EDITED: These clearances are too wide. Cold engine!- gaps should be 0.001-0.002" intake and ~0.003" exhaust) See Okierider's comment next post from Joe Henner. These settings quieted down the head, and the engine still performs great. Last edited by Thumper; 01-23-2023 at 06:54 PM. |
#426 | |
I figure he builds these into race motors so I’ll take his word for it. That is, when I get a chance to do anything lol. I need to check my clearances, install the 4* key, install the 40 tooth sprocket, install the oil cooler, and remove the cat/replace with straight pipe. Honestly Thumper et al I’m enjoying living vicariously through all y’all. Moving the homestead has been and continues to be a bear. I probably won’t have much time to wrench until winter.
#427 |
I had added the 42 tooth rear sprocket, but still wanted taller gears, so got the 14 tooth front, and installed it with no grinding, it was tight, but it went on, is pretty close to the gearing I was looking for, but it could pull even taller gearing.... will probably run this for a while.
#428 | |
Oh yeah... post 14 ![]() Last edited by Thumper; 07-25-2022 at 06:52 PM. |
#429 | |
#430 | |
#432 |
Base Templar is back in stock on the site, no X yet. I called again yesterday and was told they can't say a definite date but it could be a month.
#433 |
So they were talking about this model when they said by end of the month.
I do like the lime green. $1600 plus $300 shipping is not bad at all! |
#434 |
Seems they add and drop new stuff on the site regularly, so just keeping fingers crossed that the X is also in soon. I'm also in a back and forth with a local about a KLR650.
#435 |
The X should be getting delivered tomorrow fingers crossed…
