Old 10-02-2014, 02:50 AM   #481
I have my shirt, and I would also buy another T-shirt, Fish. If you are interested in this project, please start a new thread on this topic in the Off Topic/General Discussion Forum.
X2 on both points.
Old 10-02-2014, 03:19 AM   #482
I believe you're right.
Looking at the NC250 engine parts diagram, I can verify I was correct. Part #19 in the following diagram is the automatic decompression assembly.
At low engine rpms this assembly protrudes from the bottom of the camshaft, and contacts the roller rocker of the exhaust valves. It partially opens the exhaust valves on the compression stroke, reducing the compression as the engine attempts to start. At higher rps the centrifugal force overcomes the spring, and the lobe swings inside the camshaft, returning compression to normal.
Here is the part listed at Taobao.
http://item.taobao.com/item.htm?spm=...97&ns=1#detail
Old 10-02-2014, 03:22 AM   #483
That's a cool shot. I like the orange handguards on the bike on the far right. The header on the same bike looks to be rusted, which is too bad. I thought they were stainless.
The stainless exhaust header you saw was on Recracer's Megelli. The Zongshen RX3 has many great features, but it doesn't have a stainless steel, exhaust header.
Old 10-02-2014, 03:41 AM   #484
Indeed. A true 7.9" travel would be a nice surprise. If it turns out to be fact, I can see buying a set for Lifanda.
I wonder if the rear shock is also equipped with a schraeder valve for charging with Nitrogen.
Here's a fuzzy photograph from the Minsk TRX 300i Owner's Manual.
Do you think that little nub is a schrader valve?
Old 10-02-2014, 05:17 AM   #485
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Looks like CSC will be offerring a number of accesories. Found this doodling over at the CSC blog.
Looks like there will be rear sprockets
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 10-02-2014, 09:43 AM   #486
Motomapper   Motomapper is offline
Parts Manual Converted
Motomapper,
Can you please use your text recognition tool to convert the NC250 Engine Parts Manual to readable text? The parts manual is located at the following link.
http://svitmoto.com/GEON%20engine%20250%20(4V).pdf
Unfortunately the images were lost in the translation but the text converted. Here's the link:
http://1drv.ms/1tk0gWa
http://2wheelevolution.weebly.com
Future Cyclone RX3 owner
Old 10-02-2014, 10:42 AM   #487
Perhaps the Megelli header can be made to fit.
Old 10-02-2014, 10:43 AM   #488
I can see what you mean. Thanks for the diagram.
Those cam chain guides look a lot like Honda parts.
Old 10-02-2014, 10:46 AM   #489
I doubt it. Nitrogen shocks typically have a reservoir for that purpose, with a heavy rubber bag inside. The Nitrogen pushes against the bag and pressurizes the oil.
I couldn't tell from the other pics of the shock was reservoir-equipped, and it looks like it is not.
Old 10-02-2014, 12:32 PM   #490
G19Tony   G19Tony is offline
G19Tony's Avatar
Very nice. I was thinking that if tubeless wire wheels were available, I would definitely spring for that.
If anyone lives in Salt Lake, they could take it to Ricochet and see if they would make a bash plate for it.
I'm thinking that the Highway Dirt Bikes universal handguards would work. At least I will try it on mine.
Old 10-02-2014, 01:52 PM   #491
That's okay, we already have the images. I just wanted the text. Thank you, MM.
Old 10-02-2014, 01:59 PM   #492
Thanks for posting the good information, Mark. I didn't know Joe was a physician; I can hardly read his handwriting.
Here is the list I can decipher from the drawing.
Exhaust Systems
K&N Air Filter
Racks for Luggage Uppers
Hard and Soft Baggage Options
Additional Racking
Seats
Heated Seats
Enclosed System for Fording Deep Water (EFI Throttle Tube)
Paint
Tank Bags
Lever Brush Guards
Built-in GPS Options (Digital Dashboard)
Driving Lights
Panniers
Tubeless Wire Wheels ala BMW
Engine Guards (Skid Plates)
(Foot) Pegs
Center Stand
Gear Ratios (Sprockets)
Tires
Heated Grips
Taller Windshield
The Russian reviews talk about a heated grip option. Some of the Russians also said the stock windshield was too short. Fortunately, we early adopters are getting the taller, clear windshield.
Old 10-02-2014, 02:01 PM   #493
If the Megelli exhaust header fits behind the engine guards, it might be less vulnerable than the stock exhaust header. Also, the placement of the 02 sensor might be more protected.
Old 10-02-2014, 02:08 PM   #494
Yes, both shock absorbers on my Honda motorcycles have an external reservoir, and both can be rebuilt. I seem to remember the shock absorber of the QLink XP200 has a schrader valve for setting preload; does that shock have an air bladder?
Old 10-02-2014, 02:18 PM   #495
I have the Tusk hand guards installed on my ZS200GY-2, and both Hondas.
https://www.rockymountainatvmc.com/p...x%20handguards
I am definitely going to try fitting these hand guards to the RX3 fat handlebars.
Here's a link to my review of these handguards.
http://www.chinariders.net/showthread.php?t=11247
