#526 |
Could not resist. The sale is $50 less than I paid for my awesome original Templar X. So I have a spare 5 speed version, for now!!
#527 |
upgrades
Has anyone installed a new carb, air filter and or exhaust? if so what kind and what jetting for carb?
thanks |
#528 |
upgrades
Has anyone installed a new carb, air filter and or exhaust on Templar 250x? if so what kind and what jetting for carb?
thanks |
#529 | |
https://www.chinariders.net/showpost...&postcount=523 |
#530 |
upgrades
Hey Thumper have you installed a new carb or jetting? what size is good for jetting? 125 main/45 pilot? what exhaust or ir filter do you run
#531 | |
https://www.chinariders.net/showpost...43&postcount=1 I think these settings (125/45) are working (with minor needle shim). |
#532 |
New carb isn’t really worth doing.
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
#533 |
If I hadn’t bought this I’d be all over the 6 speed X…I might say screw jr and but one anyway lol
#534 |
Thumper, congrats on the bike. I’m still on the fence but mama ain’t digging a bike purchase every quarter. Between mama mentioning sanctions and the amount of work and mods done on my base, it’ll have to wait until at least October.
I’m still really enjoying the base model light weight. Seems the X has five extra inches of wheelbase and seven inches more length. On the exhaust, I used this https://www.orionpowersports.com/sta...-249cc-engine/ It doesn’t fit the base model and it requires some cutting and welding. I think it would fit the longer X model better but the stock muffler is narrow, the clutch linkage is close and so is the rear shock (it must be a hassle removing the carb with the adjustable rear shock). The benefits are a larger header pipe diameter and no cat. It would be easier to modify the existing pipe, some gents on here cut a rectangular opening on the cat bulb, scrape out innards and weld it back. That’s probably the better way to go. The new 6speed has a larger muffler and the right rear plastic appears to kick out for additional clearance. And a larger fuel tank, and alloy rims, and a case guard, and a rear rack. I’m hoping Thumper will post pics of the new model when it lands. A few pics of the new hardware and reports of the 6th click and RPM drop should be enough to push me over the fence. |
#535 |
Okie, that looks like a INT650, congrats. I looked at a RE Himalayan before finding the Templar. Here’s my day tripper
#536 |
Thumper, I don’t know if I’m going to be able to take the two weeks for pics…
In the meantime, I’ll sacrifice a bit more grey matter. |
#537 | |
Very interested in the 6 speed. Looking forward to some real data on the actual gearing ratios and vibration difference. Keep us posted! |
#538 | |
Huck 2013 Honda NC700X 2013 Moto Guzzi V7 Stone 2016 AJP PR4 2021 Moto Guzzi V85TT 2021 Sondors Metacycle AMA Life Member |
#539 |
I got this back from maxpro-llc on the 6sp Zongshen engine:
"The ZS172FMM-5 (6 speed engine) will come, but do not have ETA right now, when it will arrived at our warehouse, we will email you, or you can follow our eBay store, thanks". ![]() BUT, in the same email, he said that the tech guy was telling him the -3A an -5 are not identical (mounts). He doesn't know if the -5 can be adapted into the older frame I got a couple of months ago with the -3A. I will have both bikes side by side within a couple of weeks and will be able to look more closely at it. If the upper connection and at least one of the others hold it so the front sprocket is lined up, it should be possible to make linker plates to get the other mounts secured. Last edited by Thumper; 08-15-2022 at 02:05 PM. |
#540 |
If they aren’t interchangeable I may just wait to see if a 300 comes later.
