Old 04-26-2019, 12:23 PM   #46
wedooit   wedooit is offline
wedooit's Avatar
Thanks for all the info! I have it all book marked and saved! I would like to know if you cleaned the measuring cup before you gave it back to your wife? LOL.....I took one of my wifes measuring cups for measuring weed killer.....was her favorite.....I had to replace it....then I dropped the glass one I had borrowed.....back to the store to get a plastic one. LOL
Old 04-27-2019, 08:34 AM   #47
wheel spinner   wheel spinner is offline
I changed my fork oil last year and it was very easy to do... I removed the allen screws at the bottom of each fork and drained the oil... the old oil really looked clean... I had alot coming out of my left fork but very little coming out my right fork.... but both looked clean... I replaced the oil with clean ATF fluid... forgot what formula... I believe I put 250mml in each fork.. and it rides nice... never had a problem yet... if you decide to remove the screws from the bottom of the forks, and you can't get the screws to screw back in the forks, use a air ratchet... or a air impact that has adjustable air settings so you don't snap off the head...
2006 Roketa DB-07-200 Dual Sport
2007 Monte Carlo SS 5.3
2010 Challenger Hemi 5.7
2004 Isuzu Rodeo
1998 Kia Sportage 4x4
2004 Toyota Tundra
2016 Ford Escape
Guitars
1970 Gibson SG mint Condition
2005 Epiphone white Custom SG Les Paul L/New
Fender Banjo New Condition
BC Rich Bitch - Like New\
3 Jay Turser SG Good Condition
Amps
Marshall vs100 Good Condition
Acoustic 261 very good condition
Boss GT-6 Pedal effects Like New
Old 04-27-2019, 08:44 AM   #48
Ariel Red Hunter's Avatar
Originally Posted by wheel spinner View Post
I changed my fork oil last year and it was very easy to do... I removed the allen screws at the bottom of each fork and drasined the oil... the old oil really looked clean... I had alot coming out of my left fork but very little coming out my right fork.... but both looked clean... I replaced the oil with clean ATF fluid... forgot what formula... I believe I put 250mml in each fork.. and it rides nice... never had a problem yet... if you decide to remove the screws from the bottom of the forks, and you can't get the screws to screw back in the forks, use a air ratchet... or a air impact that has adjustable air settings so you don't ring off the head...
I think he means "wring off the head." in the last sentence...ARH
Old 04-27-2019, 10:55 AM   #49
Dumb question, assuming ATF = Automatic Transmission Fluid, any particular brand recommended?
Old 04-27-2019, 01:47 PM   #50
OR, just don't remove the allen bolts on the bottom of the fork because they aren't drain bolts and are not intended to be drain bolts. They are the damping rod bolts. Want to drain the forks, remove the fork leg, take off the cap, invert fork, dump out fluid. refill, reverse.
Old 04-27-2019, 05:10 PM   #51
The ATF I used was/is Valvoline MaxLife Dex/Merc ATF... very good results so far.... make sure you measure good and put the same amount in each fork..
I pulled the screws from the bottom of each fork because my oil was clean... you could see right through it... very clean.... I only had about 2000 miles on it ... and the reason I did change it out is because when I hit a bump... the forks would hit hard... so I change the oil and dumped the forks until no oil came out... I was ready to tear the forks down if I had to...
2004 Isuzu Rodeo
2004 Toyota Tundra
2016 Ford Escape
Guitars
Amps
Old 04-27-2019, 08:01 PM   #52
pete   pete is offline
pete's Avatar
Why the hell did they ever stop putting the 6mm drain screws in the them..
even my xt660 has a place for them but were never drilled and tapped for the screws..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-28-2019, 09:35 AM   #53
too easy to remove 2 screws .. drain oil ... replace 2 screws.... and refill... takes how long??? 30 minutes or less... versus removing the forks.. and spending an hour or so on removing the forks... I like to work smarter not harder.... I wish they would bring the screws back... make life easier...
2004 Isuzu Rodeo
2004 Toyota Tundra
2016 Ford Escape
Guitars
Amps
Old 05-07-2019, 06:46 PM   #54
jimwildman   jimwildman is offline
jimwildman's Avatar
For $10 you can mess up a bunch of plastic ones and stay on her good side!
https://www.amazon.com/APLANET-Trans...-2-spons&psc=1
500cc Hawk Project http://www.chinariders.net/showthrea...372#post281372
