02-15-2023, 08:51 AM | #1156 |
I will install and test the Naraku adjustable CDI box today, after warming up the bike on the short ride.
PSM has all three Templars available. The base model is so cheap, amazing. M and X are available, but prices are going up. $1900 is the sale price (Valentine's day) for the X.
02-15-2023, 10:20 AM | #1157 |
It's not that bad. I've been riding for years and years and a few times people have asked me which bike they should get. My basic answer is to get one that makes you feel good every time you look at it, even if you can't ride it at the moment. This one has got me there. It needs a little help and is a bit scruffy right now but it makes me happy enough to open the garage door and see it there. People do say sometimes I've been blessed with a bit more patience than average too though.
02-15-2023, 11:40 AM | #1158 |
adjustable CDI installed-WORKS
It took fifteen minutes to set up, remove the side cover and swap out the CDI units. Just to refresh your memory, this is the Naraku adjustable AC CDI box.
My testing confirmed that Templar X (with Zongshen 172FMM-3A) has an AC type CDI unit. It started instantly. I did not adjust it before install. They claim it is shipped at zero position (no advance/retard dialed in). Note, all you have to do is remove the right side cover to get to it. If you haven't seen my right cover mod, here it is. I just cut a slot above the rack mount so the right sidecover slips off without removing the rack (just remove the 2 8mm head bolts). This makes removing the exhaust MUCH easier too (leave the seat AND rack in place): The original rubber mount fits, but I didn't bother to install the CDI properly for this test. I installed it afterwards. This will be easy to adjust/test once we have a nice warm day. Here is the video:
02-15-2023, 12:06 PM | #1159 |
I'm curious it makes any difference.. I had installed an orange non-adjustable cdi on my former Titan DLX that also claimed to advance the timing and remove rev limit, and other than rev limit, i couldn't really tell any difference power-wise
02-15-2023, 03:09 PM | #1160 |
My gut tells me that if this is set for an aggressive advance on this device, with a ported head and a long duration cam you would FEEL it, but it would also push to overheat this air-cooled cylinder. Now you are talking oil cooler or don't push it for more than a few seconds on the trail for something important (like a LONG wheelie )
But, as a standalone mod, it might be perceptible on a dyno. I am waiting for a head, already have a ~265cc cylinder kit, and I would like to open up the exhaust to hear that nice thump you can get with these bikes and get the gases out easier (with cat-gut). For now, I will do some testing on the advance mostly to see if the engine is "happy", and try to figure out how many "clicks" to go. But I turned it clockwise. I could detect NO CLICKS. It turned just over two revolutions and stopped. I set it at ONE revolution/turn. Test drive now. I don't care if it is 45F. Brrrr! After the ride? It runs fine and who knows if there is another hp or something. The exhaust note cracked a bit more on throttle blip. But this is one cold-assed test. It seemed at least as powerful, felt great. All of the above applies. ignition advance is useful, but it is only a part of the quiver of tools you have to increase hp. And if you use them all, better cool that thing somehow if you want to use it continuously!!
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 02-16-2023 at 02:49 PM. |
02-16-2023, 11:44 AM | #1161 |
Been out for a bit, tax season and all taking away more of my focus but I have been tinkering with my Templar in the background, some of what I got up to:
02-16-2023, 11:50 AM | #1162 | |
Can confirm, they only assembled the headlight on mine making sure the various screws were screwed in, but it had not been adjusted at all. I spent one night when I first go the bike and took it to my neighborhood street on one end, pointed the bike down the street towards the opposite end and used the adjustment screw to adjust the high beam against the reflective stop sign and houses at the other end of the street. I don't ride at night but its a simple enough job to adjust the headlight so its not shooting down UFOs in the sky. If I rode it at night I would definitely change out the LED bulb with something brighter.
02-16-2023, 03:15 PM | #1163 | |
02-16-2023, 04:43 PM | #1164 |
Got mine today!
Delivery driver was super cool. He unloaded it and rolled the pallet into my garage, then helped me unbox it to check for damage. Happy to report thus far the only noticeable thing is a small mark on the bottom left fork by where the axle is. The M.C.O. arrived in the mail on Tuesday. Was bummed to see "Off Road Motorcycle" under body type. May stop by my local dmv first and see what they say about getting it plated before I email XPro about a new certificate.
Templar X 250 Yamaha XSR900 Kawasaki Brute Force 750 Yamaha TT-R 50 |
02-16-2023, 05:48 PM | #1165 | |
Starting to wonder where my paperwork is, the bike arrived two days ago. |
02-16-2023, 07:33 PM | #1166 | |
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 02-18-2023 at 01:02 AM. |
02-17-2023, 08:31 AM | #1167 |
They did for me.
2022 X-Pro Templar X 250 “Rocinante” 2022 X-Pro Bolt 125cc “Dapple” 2022 Royal Enfield Interceptor 650 “Traveller” 2023 Royal Enfield Classic 350 “Trigger” |
02-17-2023, 02:23 PM | #1169 |
Contacted "Zora" about my shipping-damaged parts and they said they are looking into it. So the ball is rolling.
Probably just me but Zora is a name I've only run into once before and the picture sticks in my head. From "A Link to the past". Just me? |
02-19-2023, 12:52 AM | #1170 |
I just bought a new set of Tusk Dsport tires for the Templar 250. Can't wait to get them mounted. Will post pics
