Old 03-24-2023, 03:59 PM   #1246
Originally Posted by Zooker89 View Post
I got some more graphics applied this morning. The rear fender was a tough one...
I also realized I need to shorten the license plate bracket...
That looks good, would that be orange-licious or tangerine dream? In the photos the orange on the new stickers matches the seat cover orange very well. Was that by design or a happy accident?
Old 03-24-2023, 06:26 PM   #1247
Zooker89's Avatar
Thanks man.
On the Motocal website it is just called "orange". So....I guess you could say it was a happy accident
Old 03-24-2023, 08:00 PM   #1248
Thanks man.
Pete's right. It is a Tangerine Dream. I can't decide which is better, the original 5 speed Temp X or the late 2022 6 speed version. Either one fits the description. Only my original orange 5 speed fits the color, but they are BOTH amazing bikes.
If you have a good set of headphones, or ear buds, check Youtube for Proton Bonfire
Old 03-24-2023, 09:32 PM   #1249
A suggestion for Dual Sport rear tire is the MOTOZ TRACTIONATOR DESERT H / T HARD TERRAIN TUBE TYPE. I started using this last season it preforms extremely well in every terrain I've run.
I continue to eyeball PSM for 300cc bikes but nothing yet.
There's a newcomer hitting US market this year KOVE keep your eye out for this company it looks very promising! The Parent company is Tibet New s
Summit Motorcycle CO. I'm honestly considering the KOVE 450 Rally but its the new NC450 Zongshen motor with double overhead cam version no parts available yet..
I've been running this Templar X 5 speed hard for a solid year as of today March 24th. Purchased a Xtra set of tires and swap out from Factory 13x50 to 14x42 often. Works for me. I can trail ride mostly by slipping the clutch reducing speed in technical situations. Found some used rear foot pegs from Yamaha XT250 fits these bikes. Also Pannier rack from Happy Trails looks promising for this bike. Will attach a link.
Got my $1800 out of this Chinese bike the first 100 miles..
https://www.happy-trail.com/happy-tr...MaAnxtEALw_wcB
Old 03-24-2023, 09:43 PM   #1250
Good info on the rear pegs.. wish I had known sooner.. one of my rear fell out while riding in the past and recently I bought a $10 generic set on Amazon and had to rig it to work, it does but definitely took some finagling to drill out the holes and get it to function
Old 03-26-2023, 04:24 PM   #1251
Chienmin Su   Chienmin Su is offline
Hi Folks,
I'm so happy to report back over the new idle speed screw I ordered it from Aliexp and it took a while to arrive but it works. Unfortunately the big Knob actually is a small knob, only slightly bigger than 5/8", but it worked. I took it out for a run for about 15 miles and was impressed how much power it has. Mine is X-pro with 6-speed but #6 will not show on the instrument gauge, haha. Only show up to #5. Since it's in break-in period, I only tried to ride on 55mph @6K rpm. it'll go higher if I pushed it. I'm a happy man finally.
Now, here is some help I need. The engine will start right on if I had the choke lever fully depressed. I need to hold it and adjust the idle speed screw (ISS) to close to fully closed until the exhaust pipe red hot then I can relax on choke, or, the engine will bog and die. Once the exhaust pipe is red hot ( about 4-5k rpm), I can lower the rpm to 2.5k for idling. Is this okay with normal operation?
Also, during riding, once I relaxed the throttle to zero, it bogged a couple at all speed, is this normal or I need to re-jet. Today here at Cincinnati is around 60's.
Frank
Thank you so much if any tips/advices offered !!
ID:	28890   Click image for larger version
Old 03-26-2023, 04:36 PM   #1252
I had the exact same symptoms when I drilled the airmixture screw cover and opened it to ~2 turns. Close that down until it behaves. Mine likes 1 turn, or even a bit less, but I changed to a #42 pilot jet (up from #40) as well. If you haven't rejet, START there!
https://www.chinariders.net/showthread.php?t=32177
Look at post #4 for links to rejetting info.
Old 03-26-2023, 04:56 PM   #1253
Tank you so much, you folks are the best!!
I'll do as instructed and report back.
Frank
Old 03-26-2023, 05:01 PM   #1254
Is it necessary to stay within 35 mph during the break-in period as the manual suggested? I have a hard time to not go over 50 mph when road condition permits.
Frank
Old 03-26-2023, 05:17 PM   #1255
It is rpm, not speed that you need to watch. Keep it under 6000rpm and don't give it full throttle when rpm is high, especially.
Old 03-26-2023, 09:30 PM   #1256
DanDLion   DanDLion is offline
I was wanting to find an analog oil temp gauge to monitor my new Templar X. I saw throughout this thread the Suzuki RMZ250 was quite a similar bike to the Templar. So I took a chance and bought this oil cap gauge which fits that Suzuki. Can confirm fits the Templar X perfect! (Note: this is the HTT-2 model)
https://www.amazon.com/gp/product/B0...rod_image&th=1
I am having trouble getting the Templar to start for the first time. Right now I am thinking its either valves, or carb is clogged perhaps. When I get it running I will update on if this temp gauge works/provides some value.
Old 03-26-2023, 10:11 PM   #1257
It should pop to life instantly, Dan. Could be a wiring thing. Was this pre-assembled?
Old 03-26-2023, 10:33 PM   #1258
Thanks Thumper! Those are encouraging words to hear while I troubleshoot this. Haven't ridden in 15 years and cant wait to cruise some trails.
I assembled it myself, tried to take and my time and do it right. Electrical seems to be in working order with new battery and she turns over really well. I did pull the plug and visually see spark (possibly could have been stronger). But even after 10-20sec of cranking I cant get it to fire once, and when I pull the spark its dry and doesn't smell of gas... And I confirmed fuel flow downstream of the fuel filter...
Megadan suggested valve adjustment which I agree needs to be done. Didnt think valves out of adjustment would cause an issue similar to this though. I am really starting to suspect fuel is not getting into the engine, although I do believe it is getting to the carb... Valves seem easiest to adjust first, then onto pulling the carb, unless the wizards here can send some magic my way.
Old 03-29-2023, 05:21 PM   #1259
Twowheeler   Twowheeler is offline
The dipstick can break off is it is not installed correctly. If inserted at the right angle the end will get caught somewhere around the shifting mechanism and put a bind on it. It wouldn't be the first time that has happened on a few bikes posted on here. If you have a site glass you will not need to use the dipstick anyway.
I wish my 2022 M, had a siteglass. The dipstick will have to do.
Old 03-29-2023, 08:11 PM   #1260
WeebleWobble   WeebleWobble is offline
WeebleWobble's Avatar
You can verify if fuel is making it to the carb by opening the bowl drain screw and see if any fuel comes out.
Templar X 250
Yamaha XSR900
Kawasaki Brute Force 750
Yamaha TT-R 50
