03-29-2023, 09:02 PM | #1261 | |
03-29-2023, 09:38 PM | #1262 |
I grabbed one of the HTT-2 & I can confirm it's a perfect fit on the ZS-172FMM 5 speed. Thread orientation alignment it spot on and quality is high. Thanks DanDLion for the information. Hope you get your bike up and running...
03-29-2023, 09:43 PM | #1263 |
What kind of temps are you seeing after some riding?
03-29-2023, 10:46 PM | #1264 | |
Thanks Nutcracker, I have been putting in a lot of late nights this week to get a project out on time. But come this weekend I will have some time to wrench and update! |
04-03-2023, 01:09 PM | #1265 |
Stole a little time. The replacement (red) stickers for my (silver) bike had transfer paper on them. Kind of see through. So I traced the stripes and numbers on that and then transferred it to the vinyl I bought with an Xacto knife. First time using vinyl wrap and I expected to redo it but it came out pretty well. For the second attempt I'm going to scan the stickers onto the PC and then talk my buddy into running them through his vinyl cutter.
The vinyl was a perfect match. The silver OK, but too glittery. The gray....too dark. OK from far enough away. No big deal. A lot better than the original damaged one. Went to my daughter's and helped the ATV's destroy her back yard a bit. Enough room and dirt to stretch its legs a bit. Fun. Two son-in-laws gave it a ride and approved. One said he had to get off, it had enough power for him to get in trouble. Other hadn't ridden in literally years. I think he just got the bug to start looking at bikes. Looking at fender mud I saw a couple of tail light wires had come off again. Fine. Added a bolt and tab though a dimple in the plastic and then a carefully placed smaller one of to the side. Then a piece of plastic conduit over the connectors. I don't have a lot of faith in even this being a permanent fix but I'm sure it's better than dangling wires. And while I had all that I finally swapped in my uprated battery. Noting the miles stayed on the odometer like they should. Only 20 miles. Going to be forever before I get this thing broken in. |
04-03-2023, 02:36 PM | #1266 |
I saw 175°F after my first 3 mile ride.
And 200°F after my second ride at 6 miles. Both rides with minimal idling, and keeping speed and rpms low for break-in period. So it does seem to work, although I would like to stick a meat thermometer down into the oil after a ride an compare it to this gauge. |
04-04-2023, 11:17 PM | #1267 |
I really like that oil temp gauge/cap but can't find one other than HTT-1. I did find the manufacturer. Now I need to measure my oem oil dipstick unless someone already knows the length. I'm hopeful that one of these HTT-3/4/5/6 caps will work.
22 Templar 250 |
04-05-2023, 07:38 AM | #1268 |
Please keep us posted, also want to get one if we can figure out which works as an alternate
04-05-2023, 04:25 PM | #1269 | |
Edit: I contacted HTT and will post back when I hear from them. I found similar items on Alibaba but not as nice looking.
22 Templar 250 |
04-05-2023, 04:35 PM | #1270 |
I thought these were just a cap that screws in and reads temp, no actual dipstick?
04-05-2023, 04:42 PM | #1271 | |
A dipstick would be nice, or even better yet a sightglass hmmmm |
04-05-2023, 04:59 PM | #1272 |
The HTT-1 & 2 are oil caps with a temp gauge. HTT-3 thru 6 also feature a dipstick (as shown in the link I posted). I would be okay with HTT-2 but if possible would prefer having a dipstick also.
22 Templar 250 |
04-06-2023, 03:42 PM | #1273 |
I ran across this and it reminded me of the last posts. This is what some folks in the Harley side do. Just a simple metering if needed and keep the oil cap and dipstick plus a general routine to get going on a cold start.
I don’t have any oil measurement and not planning it. I’m pretty bog standard Templar owner, I even still run oem spark plug and carburetor only changing out the jets, I have nearly 600 miles on the clock and no valve adjustments. I start and warm my bike up while finishing gearing up before starting a ride and I go slowly through the neighborhood estate before reaching an exit and starting to really flog the throttle. So far it’s been running like a dream without issues. The only change I did for high speeds is moving my fork adjustments back towards the triple tee top. Ever since then I’ve not adjusted anything on the bike. Just clean the chain and lube every month or so.
04-06-2023, 05:02 PM | #1274 |
Pete... adjust those valves. It is pretty easy on these 172FMM engines and it WILL make it run better.
Remove the spark plug, remove the side cap an put a 14mm (15mm?) socket onto the end of the crankshaft (stator side). Open the sight capjust above the stator, and you are halfway there. Pop the exhaust valve cover (crescent will do). Rotate the crank counterclockwise to the | T mark. The valve is open, or closed. Rotate it another 360 degrees, it is open or closed. When you figure out which is valve closed (gap open), set it to 0.001-0.002" I find that this is 1/8th turn from gentle full close to no gap. Cap it up and repeat on the intake... done. This gap just barely feels perceptible by hand on the rocker. Perfect. This is OHC, and there are no long rods to exacerbate heat changes, so these are tight clearances. Go for it! Tell us if it makes any difference. It may idle more stably, rev quicker, more smoothly. And it will protect those valve seats!
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 04-07-2023 at 02:57 AM. |
04-07-2023, 12:18 AM | #1275 |
HTT hasn't responded yet so I ordered one of these to test fit. If it fits I'll cut the dipstick to length and score some notches in for low/high oil level.
Techtip: If you want to make a dipstick easier to read use some sandpaper.
22 Templar 250 |
