05-15-2007, 02:19 PM | #1 |
Increase performance?
Im one of those guys always looking to go faster. So after reading about the mods on here with exhaust and intake, with people looking for that little bit extra..... I was inclined to put an email into a long time guy Ive delt with for over 20 years at LA Sleeve. Over the years on many bikes I have sent out a cylinder, piston and head and typically turn around time was 2-4 weeks. This has resulted in increasing a motors cc up 25-75 cc. I have made 125's up to 150cc, 250's to 300 etc.
So the email I sent was a descrition of the Lifan motor; its bore and stroke dimensions to see if it is possible to increase the cc's of the motor with maybe an aftermarket bit from Weisco for example to fit an XR250 etc.... by 25-50cc which would provide a whole lot more grunt...that is if the bottom end can handle it. Once I get a responce I will let the board know. If this is do-able it would be very interesting to see how well one of these bikes would perfom...Talk about creating a dual sport China sleeper. Can I hear wheelies at will? |
05-15-2007, 02:58 PM | #2 |
I think the lower end will take it easily as long as you didn't spin it any higher, and kept the piston weight the same. I would think a 250 cc bore job, head porting, larger valves, bigger cam, the lifan 30 mm carb, and a good aftermarket exhaust would net 22 - 25 HP. The trouble is you just doubled the cost of the bike whose primary benifit is affordability. But these exact thoughts have been coursing through my mind since I've owned the bike. I say, "GO FOR IT". Your bud should produce a bolt on big bore kit. I'm sure it would sell.
05-15-2007, 04:30 PM | #3 | |
05-15-2007, 08:56 PM | #4 |
I would be more worried about a balance issue with a heavier piston. I bet you could get a custom piston made to whatever specs you need, and they could build it light to match the stock weight. Since you already have the bigger Lifan carb, you could go to 250 cc, port the head yourself, do a pod air filter and slip on muffler. I bet you'd be right around the 20 HP range, and that most certainly would be noticable. Go for it man!!!!
05-15-2007, 09:01 PM | #5 |
I think it would work, I would like to see 50cc more oomph also. Over on the Hyosung site, (I know, different motor) the dealers in england will bore out their XRX 125 to a 150 with a Honda piston, or 175 with, I think, a Suzuki piston.
05-16-2007, 08:56 AM | #6 | |
Re: Increase performance?
5 years down the road from now the Japanese will have very stiff competition.....
The destination is merely a by-product of the journey. '06 KLR650 '06 XT225 '92 XT225 Serow ( MBD.... Multiple Bike Disease...) |
05-16-2007, 10:36 AM | #7 | |
[quote="blimpman"]
05-16-2007, 11:23 AM | #8 | |
I say go for it, but I'd have that flame retardant jock strap ready.
Frostbite "The beatings will continue until moral improves" |
05-16-2007, 12:00 PM | #9 | |
[quote="frostbite"]
05-16-2007, 12:19 PM | #10 | ||
I'd agree that people use these bike for many different reasons.... I'd get asbestos socks too....
Please post all the experiments! It will improve everyone's knowledge. Basically the true reason for this site, right? It's all good!! [quote="30-Arider"] Quote:
05-16-2007, 12:29 PM | #11 |
[quote="blimpman"]I'd agree that people use these bike for many different reasons.... I'd get asbestos socks too....
Please post all the experiments! It will improve everyone's knowledge. Basically the true reason for this site, right? It's all good!! [quote="30-Arider"][quote="frostbite"][quote] *****Hey I may not have to experiment much cause it seems we have quite the mechanical technician on here already...on another thread someone claims to have ported and polished thier head, removed the Choke (Ive never owned a 4 stroke that starts well without a choke but what do I know), advanced the timing etc. |
05-16-2007, 02:12 PM | #12 |
On a serious note, I have given this some extra thought. Using low cost vs performance as my premise, I put this thought out there. How about leaving the cc's at 197? No matter how you ramp up the displacement to 250 +, it's gonna be pricey. And, increasing the displacement without increasing the surface area of the engine for cooling purposes is asking for trouble. How about some head work? I did up the numbers quick and .033 shaved off the head will take the 9.2:1 CR to 10.5:1. That's about the safe limit of an air cooled engine on pump gas (super). While the head is off, hog out the ports and valve pockets as much as you feel safe doing, then a little bit more . Don't have to worry about coolant leaks so go crazy with the die grinder, but the material around the valves IS important to avoid heat cracking. Add an aftermarket CDI box (an XR200 box will work, I believe). This alone should give quite a bit more top end and let the motor spin up to 9500 rpm or so. I think it'll take those revs and not break. For sure this would be complimented with air intake and exhaust mods, but those are cheap enough. I bet you could get some pretty decent umph for a few hundred bucks. Thoughts???
05-16-2007, 04:38 PM | #14 |
Ok well first off I'm not big into engine rebuilding so school me please on these thoughts.
First thought/question: how hard is it to rebalance an engine? If a larger/heavier piston is used can the engine be brought into balance or is it just a pure match up game? second (silly, simple) thought/question: Does anyone have one of the 250cc engines out there to compare to the 200cc, how much of a difference is there between the cylinder/heads. I know a lot of things would have to come together but I wonder just how much they changed the 200cc and 250cc engines. Thoughts anyone? |
05-16-2007, 05:53 PM | #15 | |
For me though, Im a no replacement for discplacement kind of guy. I think a piston even if an expensive Weisco, with being resleeved wont be much more than max a $300 investment as well. Im not one who is big on high RPM power unless its s motocross bike....but for a dual sport or enduro kind of bike Id much rather have the increased power down lower in the RPM range from CC's instead of increased RPM ability. Just my taste is all. Like I said Im waiting to hear back from my LA sleeve connection on this. |
