Old 08-02-2012, 04:18 PM   #1
Took The Beast to work today!
An unusual sight unless you are at a motocross track. A YZ parked at an office.
Roger and I are riding after work so I thought I'd save some time and try out my new dual sport kit. :P
Old 08-02-2012, 04:35 PM   #2
katoranger's Avatar
Is that a spot of oil under it?
Old 08-02-2012, 04:46 PM   #3
I was waiting to see who would be the first to notice... :wink:
Yes. It's normal.
These motocrossers have no method to trap, burn, or recirculate oil in the crankcase vent system. They simply allow condensed oil vapors to drip out onto the track, or sidewalk in this case. The crankcase vent is simply a rubber hose from the top of the head to the lower left side of the frame.
Old 08-03-2012, 01:31 AM   #4
The new plastic looks great! What headlight did you mount?
Old 08-03-2012, 11:34 AM   #5
Thanks Brother Spud!
It's a Polysport. It came with a BA20D bulb which would have had WAY too big a draw on it's little batteries. I replaced the socket with a GM style 1157 unit. Miraculously perfect fit, BTW . Now I run a VERY bright 28 LED 1157 which works great as a low and high beam with minimal power draw.
The plastics are Polysport as well. I caught a killer deal at RM ATV/MC and replaced the entire body for about $100. Add $40 for a can of correct pait for the frame touch up and I think the bike looks pretty good. 8)
Taking it to the Blue Mountains tomorrow for some forest single track. Going with Andy, Roger and Tony. Look for a ride report soon.
Old 08-09-2012, 01:51 AM   #6
Pliskin   Pliskin is offline
Originally Posted by FastDoc
It's a Polysport. It came with a BA20D bulb which would have had WAY too big a draw on it's little batteries. I replaced the socket with a GM style 1157 unit. Miraculously perfect fit, BTW Very Happy . Now I run a VERY bright 28 LED 1157 which works great as a low and high beam with minimal power draw.
I am curious about this because my Zong uses bulb with BA20D base. Would this work on Zong do you know? How bright is it compared to stock incandescent bulb?
Zongshen 200gy-2
Old 08-09-2012, 02:17 AM   #7
FastDoc can report on the brightness of the 1157 LED bulb. However, I can testify an H4 incandescent bulb produces great light with the stock, Zongshen headlight reflector. You can read about my H4 headlight conversion in the following thread.
http://chinariders.net/modules.php?n...ewtopic&t=8773
Old 08-09-2012, 11:29 AM   #8
Spud's headlight is excellent.
I used the 1157 LED not because it was brighter but because it used MUCH MUCH less power and would allow my total loss electrical system to function longer on a charge. I did not choose it to be brighter as I don't plan to ride this bike on the street much at all, and likely rarely after dark at that. :wink:
With that said I'd say the light output is similar to the BA20D, but 'whiter' with a blueish tinge. It is not as bright as a halogen, not even close.
Old 08-09-2012, 01:45 PM   #9
Thank you Spud. I remember seeing i think FastDoc was riding your Zong with light turned on. It was very bright.
Thank you FastDoc. This is what i wanted to know. :wink:
Zongshen 200gy-2
Old 08-09-2012, 02:17 PM   #10
Also the halogen conversion would be easier and cheaper than the LED conversion. Again I had very specific needs to go with the LED that you don't have. I endorse the halogen bulb in your case.
Old 08-09-2012, 02:24 PM   #11
Did you perform the H4 headlight coversion, Pliskin? :?: If not, the H4 headlight conversion for your Zong is very easy. Merely solder an H4 connector to your headlight wire. Then remove the tab from the bottom of an H4 headlight bulb before you install it, as shown in the photograph above.
Old 08-09-2012, 02:24 PM   #12
Good point. :wink:
Zongshen 200gy-2
Old 08-09-2012, 02:28 PM   #13
No I haven't Spud.
Zongshen 200gy-2
Old 08-09-2012, 02:39 PM   #14
Spud,
Is the base of the H4 the same as a BA20D? If so, and if I had known that before I could have saved a bunch of time and money. Also I may still change my 1157 to an LED H4 and use my BA20D socket. I bet that would be more light.
Old 08-09-2012, 03:34 PM   #15
If you mean the socket that you plug in the bulb, I don't think it is. Here is the video I just found a guy compares led H4 vs H4 bulb.
Zongshen 200gy-2
