Old 12-11-2012, 05:19 PM   #1
candyman   candyman is offline
150cc dirtbike chokes out
starts up first kick idles good right when you start off it wants to go then bogs out. if you give the throttle just a tiny bit itll slowly accelerate till higher rpms then bogs out so you can get goin a little bit just by shifting early but cant get a good deal of speed going.
cleaned the carb even though it was clean. airscrews omost all the way in. read http://forums.atvconnection.com/chin...-sunl-etc.html
said something about an e chip in the carbu. you guys think this is the case? and how hard is that to do?
Old 12-11-2012, 05:21 PM   #2
its also around 30 degrees F here today so its pretty cold out.
Old 12-13-2012, 12:11 AM   #3
humanbeing's Avatar
This bike? http://toronto.kijiji.ca/c-cars-vehi...AdIdZ439388502
At this temp choke ON need. Valve clearance within limits?
Useful materials for this pushrod 150:
Carb: http://www.lincolndod.co.uk/PZ%20Car...g%20Manual.pdf
Generic: http://hondacg125.awardspace.com/
Shop Manual: http://uploading.com/files/7985bmfe/
