TMEC GY200 with custom 40 tooth rear sprocket
Finally, after a week, my friend, with a little help from me, installed the 40 tooth sprocket and chain (it didn't take a week, it was coordinating around our work schedules). Initially, the best thing that could happen to a TMEC 200 based on a quick blast to the gas station and back. However, will have to wait on a report since it has been raining the last day and a half. Monday will be my regular commute, so that will be the true test.
Congratulations.
![]() Spud ![]()
Ok, minor/major snag. 3 of the bolts had broken off the sprocket on install. The 3 remaining bolts started loosening up on my test ride. However, it completely changed the character of the bike while it worked...for the better. Tightened up the 2 working bolts, andgot it home. Bought replacement bolts, hex head type. Put permanent thread lock on the 3 and tightened themdown, hopefully permanently. A friend and I tried to extract the broken ones to no avail. Either find someone or someplace to extract the 3, or buy a new wheel :x
However, like I wrote above, before the issue, it worked extremely well. The speedometer is broken, but it had no problem keeping up with 50 to 55 mph traffic. It did remind me of my '93 Mustang GT in that 5th gear is overdrive (my car came stock with 2.73).
I'm sorry to hear of the broken bolts, but I'm glad you could ride home to repair them.
![]() Spud ![]()
Excalibur has a couple parts bikes, so if they haven't sold wheels, they should have one.
Search the local tool shops for left-hand drill bits (no, I'm not kidding). Lay the wheel on a flat surface, start a center punch mark in the center of the broken bolt, and slowly begin to drill it out with the drill in reverse, with a bit that is smaller than the bolt diameter. Take care to not break the bit. Have some type of lubricant handy to apply to the bit every few seconds; I use Rapid Tap, but even WD-40 will meet your needs.
The bolts might just begin to back out during the drilling process. If not, use a quality extractor (Easy-out is one brand) and remove the bolts that did not back out upon drilling. Please take pics.
Thanks for the tip, Weld, but I don't have the patience, skill, or equipment (my drill is not working, I just pulled it out and it was no go
![]() I am at the point of reusing the stock sprocket and chain on the new wheel and just sellingthe bike. :x
I'm glad you got home safe.
Sorry to hear about your troubles. I know you were in the market for a CB for a long time I'm sorry that it turned out this way. ![]()
Happy to serve. |
#9 | |
![]() Spud ![]()
#10 |
It wasn't the bike's fault, other than the crap stock sprocket :evil:
#11 |
Ok, after (relatively) enjoying the 40 tooth rear sprocket, I think I need a new front. The stock one is 17 tooth, so I think a 15 tooth would make 5th gear usable. The TMEC 200 uses the Zongshen 167 FML engine. I am sure we discussed sprockets 6 or 7 years ago, but I don't have the time or patience to search for the thread if someone knows what aftermarket sprockets fit the Zongshen/Lifan engines. I might even remember that they all interchange?
#12 |
could you drill through the hub and then choose new bolts? if your drill was working?
gentlemen, is that a possibility? i had a garelli moped where i did that, to go from a 43 to a 22. it depends on the hub, of course.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS ![]() |
#13 |
Pretty sure this is it, but you'll have to measure your CS sprocket and confirm: http://www.jtsprockets.com/catalogue/model/5065 I'd drop only one tooth and then evaluate; CS sprockets are cheap.
#14 |
Thanks for the link, Weld. It looks to be the same size (dimension-wise) as some I found on a site called www.buyatvsonline.com when I went to the Chinese bike part sections. I bet the JT would be worth a look. I agree that 16 teeth might be a good start since they are relatively low cost and easy to install. If it still seems like too much overdrive in 5th, then a 15t would probably do the trick.
#15 |
JT makes a decent CS sprocket, and I don't think I've ever paid more than $15 for one.
