battery for e-starter?
what kind of battery is best for an electric starter motor on a 230? the crf 230 service manual lists a 4 Ah battery. any experience and views?
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS ![]() |
If had $$$ Li-Fe battery because it weights LESS. http://item.taobao.com/item.htm?id=17070879605
yes, humanbeing, i have to get one of those!
the zong has a 7 AH, the suzuki a 7.5. the 4,5 of the crf 230 may be a little on the weak side? what about wires? would 2 mm wires be ok for 7 Ah?
#4 | |
humanbeing, yes, for the starter motor i have a thick cable.
but with a strong battery will 2mm be okay for other electric cable on motorcycle? if draw is less than power it should be okay or am i wrong? i don t know. :? this one looks good: http://www.exideuk.com/gel12-19-85-p.asp
Personally, I would install at least a 7 amp-hour battery.
![]() Spud ![]()
I would install the largest cable from the battery to the solenoid, from the solenoid to the starter and from the ground terminal to the frame that I could manage.
thank you for your tips, gentlemen!
this looks like a good battery and i won t have to worry about a larger battery case: http://www.motorcycleaccessoriesaust...ic-4-cell-evo2 weldangrind, u say the negative terminal should run to a ground like on a car? that makes perfect sense. but i thought on a mc it does that via wire harness and regulator? or does it need a balance for the thick red cable to solenoid and starter?
If you want to install a lithium iron phosphate (LiFePO4) battery, I suggest you get either an Antigravity battery, or a Shorai battery. Both of these batteries will crank harder, and last longer than an Evo battery.
![]() http://www.advrider.com/forums/showthread.php?t=770364 http://www.advrider.com/forums/showthread.php?t=789727 Based upon my research, I now recommend the Antigravity batteries. If size is an issue, I recommend the 4 Cell battery. http://antigravitybatteries.com/ag-401/ If you can't get them to ship to Australia, I then recommend the Shorai LFX09A2 battery, which I have installed in my Honda XR650L. http://shoraipower.com.au/store/products/lfx09a2-bs12/ This battery has performed flawlessly for me for over 30,000 miles. ![]() Spud ![]()
#10 |
I use the same ballistic battery in my bike and you can't kill 'em. I know I have tried several times accidently on purpose.
NewStar DB 200 Facts are meaningless. You could use facts to prove anything that's even remotely true! --Homer Simpson |
#11 | |
#12 |
thanks again, will implement soon and report back. two more things:
a) will the old regulator from 1980 6V 185cc be good enough for 12 V 230cc power? i guess i ll have to start her up and measure? b) would it be correct to put a 10 amp fuse in the normal circuit and none for the cables which go to the starter motor? or should i go to 20 amps? should the solenoid switch (as opposed to the starter cable) get its own fuse?
#13 |
You can fuse whichever circuits you wish, but typical China bikes have only one fuse, which is only a few inches from the positive terminal of the battery. I think the standard fuse is 15A.
I would use a regulator that is designed for a China bike. They're cheap as chips, and you can sell the Honda part on eBay.
#14 |
Ur bike powered by which 230?
CRF230F's stator = 80 watt http://www.regulatorrectifier.com/ca...ator-Rectifier / fuse: 7.5A Typical chinese stator = 1?? watt | fuse: 10A or 15A |
#15 |
spudrider, there seems to be an importer for antigravity batteries in australia, so i should be able to get one here.
weldangrind and humanbeing, it s a 230 zongshen, so pretty much a crf copy. meanwhile i found out that the xl185 regulator operates between 7 and 9 volts, which isn t enough of course. so i better get a higher capacity regulator before i hook everything up. :-)
