Old 11-24-2013, 05:51 AM   #1
overlander   overlander is offline
overlander's Avatar
broken bolt - engine mount sky team 250
After a bolt shuddering run on the freeway taking my v-raptor (retro) 250 sky team to a new top speed of 95 km, I noticed this. All that was holding the motor to the frame was one half bolt!
File Type: jpg 921279_10152083030404365_2029795036_o.jpg (79.1 KB, 111 views)
File Type: jpg 616486_10152083906134365_1297639584_o.jpg (34.4 KB, 100 views)
Old 11-24-2013, 12:24 PM   #2
Were the two bolts at the rear and one at the top still intact? I bet it buzzed like a bee.
Old 11-24-2013, 04:33 PM   #3
Thanks for another reminder to check all those engine mounting bolts, and to secure them with red locktite.
Old 11-24-2013, 06:15 PM   #4
It would also help if the manufacturers upgrated the Won-Ton noodles they make the bolts out of...
Old 11-24-2013, 08:38 PM   #5
overlander's Avatar
the top bolt fitted ( see bolt next to broken bolt in pic) was actually smaller than the hole, which was a strange setup. I put a larger high tensile bolt in it's place that I bought from a bolt shop.
Old 11-25-2013, 03:53 AM   #6
overlander's Avatar
no they were still intact. If they were loose, I probably would not be here!
Old 11-25-2013, 10:07 AM   #7
I'm glad to hear you made it home safely. X2 on Loctite.
