Old 01-22-2014, 02:26 AM   #1
migue1760   migue1760 is offline
migue1760's Avatar
yerf dog running
i got the buggy running and installed some lights
Old 01-22-2014, 12:57 PM   #2
I bet it's a ton of fun in the sand.
Old 01-22-2014, 12:59 PM   #3
That looks like a great place to run a buggy. Glad it's working!
Old 01-31-2014, 04:55 PM   #4
migue1760's Avatar
Oh No
It is fun on sand but it wasn't designed for bumps and rocks :/ it cracked a weak spot on the frame, i want to modify the back end to swivel sideways or something so it wont bend and twist the frame.
Last edited by migue1760; 01-31-2014 at 05:05 PM. Reason: putting a picture, re adjusting it
Old 01-31-2014, 05:55 PM   #5
migue1760's Avatar
i was thinking something like this
Old 01-31-2014, 08:45 PM   #6
I don't think that articulation is the key, since it would be tough to engineer enough strength. Are the rear shocks too stiff? Can you just repair the cracked area and weld in some gussets for added strength?
Old 02-01-2014, 12:55 AM   #7
migue1760's Avatar
so what should i do to the suspension? i go fast on the sand but there is rocks, little jumps, drops, and the back suspension only travels upward, its not like an individual suspension. and you can feel every rock when the rear wheels take a hit. the rear shocks are worn out
Old 02-01-2014, 09:51 AM   #8
katoranger's Avatar
I am going to suggest changing the shocks to something higher end. These stock blaster shocks should be an improvement. My buggy suspension is similar on the rear. The shocks are not too stiff. The fronts could be better.
http://www.ebay.com/itm/Yamaha-200-B...7a3d91&vxp=mtr
Old 02-01-2014, 05:04 PM   #9
migue1760's Avatar
I gotta get some money first to buy those, so im having trouble adjusting it, which screw is which here?
Old 02-02-2014, 08:53 AM   #10
katoranger's Avatar
Here you go. https://www.briggsandstratton.com/eu...the-carburetor
The screw on the bottom is the main jet, the one on the side is the high speed jet, and then one on the throttle shaft is the idle speed.
Old 02-07-2014, 09:01 PM   #11
migue1760's Avatar
ok thanks! and if i want electricity and dont have a stator can i somehow put a dc motor or an altenator from a car?
Old 02-07-2014, 09:52 PM   #12
IMHO cheaper/easier/faster to just put a battery somewhere and put it on a trickle charger every now and them.
That's what I do with my YZ400F dualsport conversion.
Old 02-08-2014, 10:34 PM   #13
katoranger's Avatar
Doc has a good suggestion. Otherwise I would use a GM alternator.
Old 03-06-2014, 11:01 PM   #14
migue1760's Avatar
Guys I bought a torque converter and im not sure if im mossing pieces
Old 03-07-2014, 09:38 AM   #15
katoranger's Avatar
Post of pic of what you have. What model did you buy?
