Old 03-17-2014, 06:59 PM   #1
oldgringo   oldgringo is offline
fuel stabilizer
I''m unable to find a fuel stabilizer here in Ecuador, my moto will be sitting a few months so I stopped by the Bajaj dealer today and asked the mechanic what to do. He told me that they don't use it here and suggested that I use WD-40. He says I would have to use a whole can of WD-40, slosh it around in the tank and run it through the carburetor, according to him, there will be no varnish buildup. Well, I'm not sure if I believe this or not, what do you guys think?
http://r1150rt.smugmug.com/
Old 03-17-2014, 10:28 PM   #2
Can you get Marvel Mystery Oil?
Old 03-18-2014, 12:32 AM   #3
pete   pete is offline
pete's Avatar
I'm just waiting for someone to invent a Rider stabilizer....
WooHoo no more falling off...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-18-2014, 12:34 AM   #4
I don't think so Doc, I've seen several brand of gas treatment but that's it. I'll sort something out tomorrow, I don't think the WD-40 would harm the moto but have decided not to try it.
Old 03-18-2014, 11:05 AM   #5
WD-40 is excellent for the original purpose it was designed for: to displace water. If you're concerned about storing your moto in your specific climate, you could drain the tank and either pour some in liquid WD-40 and slosh it around or fog the interior of the tank with WD-40 spray. Either method will help to prevent corrosion.
I'd simply drain the carb, remove the bowl and dry it out. A little compressed air will speed up the process.
Old 03-18-2014, 02:24 PM   #6
Personally, I wouldn't run WD40 through the carburetor. As usual, I think Weld has offered excellent advice.
Old 03-19-2014, 12:41 AM   #7
fuel stabilzer
Hello .. I was told that mixed fuel as used in a 2 stroke does not crap out... for short periods maybe for 6 months or more it might.. can you just get premium fuel down there??? or as WELDAND GRIND says... drain it all out.. carb & everything..
ABIBABA ATV ETC
Old 03-19-2014, 09:23 AM   #8
katoranger's Avatar
With my lawn equipment I usually just run them out of gas before storage.
For the mixed gas I buy the no-ethanol premium found at a few stations around here. I run it in the mowers and tractor too. Cost about 50 cents more a gallon than regular, but I don't have carb or fuel line problems.
I think the best thing to do is to just drain the gas and empty the carb.
Old 03-19-2014, 10:45 AM   #9
I think that emptying the carb is preferred over just running the carb out of fuel, because the fuel below the jets will remain in the bowl.
Old 03-19-2014, 03:11 PM   #10
katoranger's Avatar
The stroke carbs do not have a bowl to drain. Leaf blower, trimmer etc. I do drain the bowls on the lawn mowers.
Old 03-19-2014, 10:04 PM   #11
I find it interesting that a person can get alcohol free fuel in Kansas. Even out here in the Pacific Northwest, most fuel is contaminated with alcohol. Another option if a person cannot find fuel stabilizer, would be Aviation fuel. Aviation's fuel is very stable, and will never harm anything, even if left in for about a year.
Old 03-21-2014, 09:15 AM   #12
katoranger's Avatar
You have to look for it. The closest pump is 15 miles away, but I will get about 20 gallons at a time. We use it in all the small engines. The price is higher than premium.
There is more of these pumps than E85 pumps. My work vehicle is E85, but I cannot find a pump to fill it at.
Old 03-21-2014, 11:59 AM   #13
Not very many in your area: http://www.e85vehicles.com/e85-stations/e85-kansas.html
Old 03-24-2014, 08:44 AM   #14
katoranger's Avatar
There is a few, but none on my typical driving pattern. I can get it with I go down to Tulsa.
