07-19-2007, 02:29 PM | #1 |
What color??
Well, I striped all the junk off the front to make it easier to work on the engine when the need is there. Trying to fix a problem out in the field is no picnic with all that stuff in the way. Even taking out the spark plug is a chore.
I want to spend as little time as possible fixing in the heat. So what I need are color suggestions for the gas tank (metal). I will play with it in Photoshop but I have no talent for picking colors. I plan to paint it in the winter. It will be difficult matching the blue-purple color on the plastics. Thanks. John |
07-19-2007, 02:42 PM | #2 |
if you're keeping the plastic as it is you could maybe paint it black and put the red stripes like what is on the side number plates.... if you just want a plain color then I would contrast with the blue if you can't match it... maybe black, red, green, yellow, or white.
Are those hand gaurds purplish pink?
'20 RPS Magician 250 '06 Hensim (Tierra) DB150-2 '06 X-Treme 70cc pitbike '02 Kawasaki KX125 |
07-19-2007, 02:54 PM | #3 |
Yea, they are but they will go too when I get some brush guards for it.
Thanks. John |
