02-01-2015, 03:09 PM | #16 |
Thanks, my bud has a timing light, I already took the cover off and the flywheel has "play in it". I can move the flywheel back and forth maybe about 1/16 of a turn and the crankshaft does not move. Is this play normal?
02-01-2015, 03:30 PM | #17 |
There should be no play between the flywheel and crankshaft.
02-01-2015, 07:50 PM | #18 |
Definitely not normal. Can you show us a pic of the flywheel?
02-03-2015, 03:37 PM | #19 |
I'm having trouble uploading pictures but it looks like the the starter gear on the crankshaft has play in it.
02-03-2015, 03:38 PM | #20 |
02-03-2015, 03:58 PM | #21 |
02-03-2015, 03:59 PM | #22 |
02-03-2015, 08:17 PM | #23 |
Did you check the gaps between the changed component and the original component? This happened to me with a scooter. Though, not as severe because the part(even though it was the same part number) had a slightly different teeth gap than the original and did not fit on the spline. That engine was a QMB139.
Though, the two subjects are completely different. It can still happen. Sometimes they don't machine the part to the original spec but sell it as so. |
02-03-2015, 11:40 PM | #24 |
Ok, so it's just the gear that has play, and not the flywheel?
02-05-2015, 02:03 PM | #25 |
Yes the gear has the play, I looked closely and its not the flywheel. I think i may order a new stator, I don't have the old on to measure anymore.
02-05-2015, 02:24 PM | #26 |
Would I even get spark if the tolerances of the stator was off, I know I have spark just not at the right time. The stator actually came off a Chinese knock of Lifan and it ran fine until one day.
02-05-2015, 03:08 PM | #27 |
You might still have spark, because it relies on the magnetic pickup. On that note, is there any noticeable damage to the pickup?
02-05-2015, 04:59 PM | #28 |
IMHO the next step should be to get hold of a strobe type timing light and determine for sure that the ignition timing is off. Throwing money at new parts is a waste.
02-06-2015, 04:31 PM | #29 |
02-06-2015, 04:32 PM | #30 |
I was wondering do you see the black plastic piece? Do that have to be align straight up and down with the coil.
Display Modes | |
