03-10-2015, 11:47 PM | #1 |
Roketa DB-06 no lights!
Hey guys, been a long time!!
I went to start my bike the other day, via kickstart, and once i had it running, i noticed i have no lights at all, no indicators, headlights tail lights, nothing! i tried trickle charging my battery and i still have no lights or anything, i checked the one fuse that i know of and it looked okay, so maybe it has more than one, and it could be blown, i have the wiring diagram, but i cant really tell whats a fuse on it, and its not labeled, if anyone has any suggestions or wants to check out the diagram its here... http://www.scooterdynasty.com/manual...s%20Manual.pdf any help is greatly appreciated! -thegammaghost
2021 Boom Vader Gen 2 BD125-10 Current 2011 DRZ400S Current 2006 LIFANIZED ROKETA DB-06 200cc Sold 2008 Ninja 250R Sold 1984 Honda aero 125 Sold 1980 Honda CM400T Sold |
03-11-2015, 10:17 AM | #2 |
You're likely to have only one fuse, and if the electric start works, the fuse is probably intact. Nevertheless, it's a good idea to check the fuse with a meter to be sure.
If it is not the fuse, I'd look to the ignition switch. It has four wires, and one of them might have some off. That happened to me.
03-11-2015, 10:38 AM | #3 |
Most vertical chonda is similar to
03-11-2015, 11:06 AM | #4 |
Does your bike have a rectifier?
03-11-2015, 10:28 PM | #5 |
Thanks for the help, wierdly enough when I got home from work and tried it, the lights just all worked, not really sure what the issue was. Hope fully it stays good, thanks again!
Tgg
03-12-2015, 09:56 AM | #6 |
I both love and hate problems that fix themselves. I hope it remains fixed for you.
03-15-2015, 03:58 AM | #7 |
This seems like the same problem I'm currently having.
http://www.chinariders.net/showthread.php?t=14495 @ TheGammaGhost did you ride in wet conditions before is happened?
My CB : http://www.youtube.com/watch?v=ZbZ8q-grmOQ 2012 Skyteam V-Raptor 250 2011 Yamaha Tenere XT 660Z abs 1996 Kawasaki Vulcan 800 Classic 1989 Kawasaki GPZ 500 |
Tags |
db-06 rhm-200ed 200cc |
