Old 06-15-2015, 06:42 PM   #1
andyj812   andyj812 is offline
andyj812's Avatar
Bashan BS250Gy-9 "WIll" sprocket questons
Hello everybody again, I posted here this winter and everybody was very helpful. I need some help with my "Will" on changing the rear sprocket. I looked at some of the other threads and haven't found one that has enough information. I apologize if I haven't if its there and I have over looked it. My bike has plenty of throttle left in fifth gear at 35 mph(gps) 40 speedometer but rpms go up quickly from their and I'm constantly trying to shift up. The bike will do 56 (gps) 70 by speedometer but is really revved up at that point. It came stock with a 17t front sprocket and a 56t rear sprocket with a 428 chain. I would like to gear this down or up as much as possible without having to ride the clutch too much on take off. This bike will see overwhelmingly just street use and my never see trail.
Old 06-15-2015, 06:48 PM   #2
andyj812's Avatar
pic of Ken Sean mirrors recommended by Spudrider.
Old 06-15-2015, 06:53 PM   #3
andyj812's Avatar
pics of rear sprocket (the white is chain lube the comes out white and then drys)
Old 06-15-2015, 06:58 PM   #4
andyj812's Avatar
side view of bike kickstand seems a little long, would like to bike not be so upright when on stand. Left plastic on seat to protect seat, it seems to be wearing well lol
Old 06-15-2015, 09:20 PM   #5
Adjuster's Avatar
Man your bike looks clean. There are some great guys on here that will help you with your sprocket.
Old 06-15-2015, 09:21 PM   #6
Adjuster's Avatar
I am curious as to what the purpose of that ring is on your sprocket.
Old 06-15-2015, 09:24 PM   #7
andyj812's Avatar
I'm not sure but I think I saw in another thread it was some kind of chain catcher should the bike throw the chain, It s cleans because its hasn't been rode much and it was in back of the truck and got rained on the other day. just got it tagged the other day. it has 101 km on now, 56 km today the rest just in the yard.
Old 06-15-2015, 09:53 PM   #8
katoranger's Avatar
I would get a 44-46T rear sprocket. It appears to be the common China bike sprocket.
Amazon has them. The picture is just a stock photo. Take a look at the drawing and compare to yours.
I always use a 1980 Honda XL185S for fitment.
45 Tooth
http://www.amazon.com/JT-Sprockets-J...ype=motorcycle
44 Tooth
http://www.amazon.com/JT-Sprockets-J.../dp/B0068OC744
Old 06-15-2015, 11:00 PM   #9
That is an attractive motorcycle, and the Ken Sean mirrors look great on it.
Old 06-16-2015, 01:25 AM   #10
Nice looking bike. Either follow Kato's links, or hit eBay.
Old 06-16-2015, 02:03 PM   #11
dossbag   dossbag is offline
dossbag's Avatar
Hi, Check out this thread.. If it's the same as your set up.. then look here And you should find what you want.
2014 Bashan Storm 250 Enduro
1998 Harley Davidson Fat Boy
1993 Suzuki GSX600F - Rebuilt
1995 Harley Davidson Chopper build from ground up.
1983 Yamaha XJ900 REBUILT!
1971 Triumph Daytona 500 - Restored
1987 Yamaha FJ1200
Old 06-16-2015, 02:46 PM   #12
Carangajeira   Carangajeira is offline
Location: Swap between Bahia, Brazil, and La Libertad, Peru
Wrong sprocket fitting??
I admit to not being very savvy mechanically but those Amazon sprockets (for Honda 185) appear to have 6 mounting holes set wide out, where the picture shows 4 close in?? This is the problem I had with my Ronco when the only sprocket they sold had the 6 wide set holes, and they cut and welded my old sprocket! It appears that many of the Chinese bikes have used the Honda sprocket configuration, but Ronco and Bashan (probably among others) use a different - not so widely available - format!
Ronco Demolition 250 - Peru
Honda NXR150 Bros - Brazil
Old 06-16-2015, 05:19 PM   #13
katoranger's Avatar
The 6 hole sprocket is just a stock photo. The drawing shows the correct pattern for the JTR269.45 sprocket with 4 bolt holes.
Dossbag linked to the same amazon listing and he actually has one on his Will.
Old 06-16-2015, 05:34 PM   #14
Ah, I see Katoranger! I am trying to get my rear sprocket replaced - back to 38T and original part, but having a hard time here finding one! Would order one online, too, but postal services to here are unreliable and take so long - I only have 3 months left before I go back to Brazil, and it is worse there!!!
Old 06-16-2015, 09:41 PM   #15
andyj812's Avatar
Thanks Katoranger and Dossbag and everybody else for your help and comments. I ordered the 44t sprocket from Amazon as suggested and a new chain. It should be here Friday but not sure if I will be able to install until next week but I will keep you updated, thanks again
roketa will
