01-24-2016, 09:08 AM | #1 |
available hawk oil filter?
For you china bike engine gurus out there, on the 239 motors , there is the large cavity on the low left side of the motor that on the hawk, has a small screen, and a large spring holding the screen against the interior surface of the crankcase. the size of this cavity is so disproportionately large compared to the screen, i have to wonder if it was originally used for a longer tubular oil filter, and the mfg's have just cut some corners. ( I think CSC has a filter meeting this description for their rx3. tho it seems a tad expensive.)
Any ideas?
01-24-2016, 09:31 AM | #2 |
Everyone will tell you it's not need. Just keep up with your oil changes.
Brandon 2014 Hawk 250 Firehawk minibike Previous bikes~ 1995 Yamaha YZ125 1998 Yamaha YZ250 1981 Yamaha YZ465 1987 Honda TRX 250R X2 one stock one modified 2002 Buell Blast 2001 Buell X1 Lightning 2000 Kawasaki ZR7 |
01-24-2016, 11:22 AM | #4 |
I have not seen any of these 'traditional' CG clones ever have a proper filter. I can be most certain the upcoming CSC TT will not have one even if its 'big brother' RX-3 (which does does not use a CG) uses one.
01-24-2016, 11:57 PM | #5 |
Could there be a centrfugle filter on the end of the crank like
Honda do.... and people never clean out... ..
01-25-2016, 07:08 AM | #6 |
Yes, centrifugal filter on the end of the crankshaft is identical to the Honda CG125.
01-25-2016, 10:23 AM | #7 |
Not only the CG125, but also the XR/XL 185/200 uses the same mesh centrifugal filter.
Another point of maintenance is to remove the clutch cover occasionally and dismantle the centrifugal pump intake for cleaning. We're not likely to find as much grunge with pushrod motors as those with OHC motors. If the cam chain in an OHC motor gets loose, it'll carve aluminum and deposit it in the pump intake. When mixed with oil, it looks like anti-seize.
02-10-2016, 01:25 PM | #8 |
anyone have a photo of this centrifugal filter, i hove only had yamaha and kawsaki motors opened ... had to change the cases on my blaster when a chunk of piston broke off and went under the crank, and had to pull the crank out of my mojave 250, hope i never have to split the case on my storm 250 ... lol
02-10-2016, 06:38 PM | #10 |
http://www.motorfans.com.cn/forum.ph...authorid=75082 | http://californiascooterco.com/blog/?p=20111
02-11-2016, 03:21 PM | #11 |
thank you
06-15-2017, 06:17 PM | #14 |
Something like these "Impact Screwdriver"
https://www.harborfreight.com/impact...ase-37530.html https://www.amazon.com/Lisle-29200-H.../dp/B0002NYDRG I bought the Lisle version when it was on sale a long while back
06-15-2017, 07:18 PM | #15 | |
