01-29-2016, 01:49 PM | #1 |
Open Service Shop in Argentina
Around a month ago a local distributor invited RX3 owners to show us a complete bike service, including valve adjustment.
They gave a free service for 2 of the bikes, unfortunately not mine. One of the things they told us is that they adjust to 0,10 the valves clearance that is much higher than the values I can read at this forum. You can see some pictures of the event and a video in their facebook. In the pictures I´m the second guy from the left. This is a link to the work shop video ... https://www.facebook.com/zmotos/vide...type=2&theater
Pablo. Today Riding a Corven Triax 250 Touring (Zongshen RX3) |
01-29-2016, 10:15 PM | #2 |
Zongshen recommends setting the valve lash for all four valves at 0.04-0.06 millimeters. I personally set the valve lash to 0.08 mm for all four valves in my RX3 engine. Setting the valve lash to 0.10 mm is a little too large, but it shouldn't cause any problems, other than a minor loss of power.
02-01-2016, 12:03 PM | #3 | |
02-01-2016, 02:21 PM | #4 | |
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp, |
02-01-2016, 02:40 PM | #5 |
I haven't noticed any power loss by setting the valve lash a little on the loose side, and I prefer to have the valves adjusted a little too loose, rather than a little too tight. Also, setting the valve lash to 0.08 mm gives me an additional safety margin to avoid tight valves, in case I am a little delayed with my valve inspection, or the valve seats more quickly than usual. Finally, I believe I read somewhere that CSC sets the valve lash to 0.08 mm at the dealership before they ship the new bikes.
02-01-2016, 04:10 PM | #6 | |
02-01-2016, 04:12 PM | #7 |
Thanks for the kind words, amigo. To be more accurate, I place a 0.08 feeler gauge under the tappet as I tighten the lock nut. Usually, when I check the valve lash, it has been set to 0.08 mm. Sometimes I tighten the lock nut a little too much, and the valve lash might end up a little tighter, perhaps closer to 0.06 mm. In that case I don't bother to loosen the lock nut. I am within specifications, so I close everything up and finish the job.
02-01-2016, 08:57 PM | #8 |
OHC rocker clearance
Keith, from my experience on Honda OHC engines with rocker arms they ranged from .002" intake .004" exhaust to only .002" on both. This was on models from 50cc up through 750cc. The little pushrod engines were always larger than that. So perhaps with advances in metallurgy and forming processes, things have only improved to allow makers like Zongshen to reduce tolerances.
02-01-2016, 09:15 PM | #9 | |
He said that during the CSC "setup", the valve clearances are set to .003" jb
2016 Honda CB500F......2017 Triumph Street Twin 2014 XT 250........ |
02-02-2016, 12:25 AM | #10 |
Thank you, I read the information from one of your posts. A valve lash of .003 inches is equal to .0762 millimeters.
02-02-2016, 06:55 AM | #11 |
i too will adj. valves at .003" all my gauges are in thous. little loose is ok from what i am reading
02-02-2016, 10:46 AM | #12 | |
I learn stuff on this forum every day.
02-02-2016, 11:18 PM | #13 | |
In that vein, a 3" long pushrod will lengthen about .006" at 200F. The distance from the cam to the rocker end will also grow, but as various metals will run plus or minus to the general rule, the maker will undoubtedly determine actual recommended tolerance after running a number of practical tests. Now for overhead cam (OHC) applications it would be a bit different. The cam lobe and valve stem will expand which should reduce the cold set clearance. However the rocker arm pivot hole will also enlarge (get more sloppy) and give some clearance back. On our engines with the roller type cam follower there is also slight sloppiness. So tight is not good as it can give grief to the valve face. Loose is not good as it reduces amount of valve lift while also reducing duration, but that only affects performance. It also creates an impact that can defeat the thin oil film that would normally cushion the contact between the cam and follower, and again between the valve stem and the valve lifting end of the rocker arm. Darn, got sidetracked and forgot what I was going to say. Oh, just remembered, I had pudding for dessert. |
02-02-2016, 11:29 PM | #14 |
"Darn, got sidetracked and forgot what I was going to say. Oh, just remembered, I had pudding for dessert."
What flavor ? any sprinkles? Your leaving us hanging here Jay rj
Live Zong, and Prosper |
02-03-2016, 12:56 AM | #15 | |
Thermal expansion coefficient for carbon steels is 6.33xE-6 in/in/degF; a 100 deg F temp change adds .000633" per inch of material (the alloy steel used for the valve stems may have a different coefficient). At 200 deg F that is a 130 deg F temperature increase, so a 3" stem would grow 6.33xE-6 x 3 x 130 = .0025" But the head will also grow and it is usually aluminum; the coefficient of thermal expansion for aluminum is twice that of steel. If the rocker arm pivot hole also enlarges, the pin it pivots on will too, making that a net zero. Man, you opened a can of worms. I going to leave it for the engineers at the factory.
Dan CSC RX3 Cyclone, CSC TT250, Moto Guzzi V7 II, KLR650 |
