Rattling sound in engine - Storm 250
Hi again Chinariders
![]() Please tell me if this sounds right to you: Thanks! |
Sounds like mine, probably valve noise. Im not sure what is normal either. My best guess would be that its too much, but I still gotta dive in and readjust mine.
Hope someone more knowledgeable than I chimes in. |
I have the exact bike and mine is much quieter. I was told they come tight from new. I'm kinda happy with the way mine is.. I know Evelyn got her bike pre-assembled from a dealer. So not sure if they did a proper service on it or not.
2014 Bashan Storm 250 Enduro 1998 Harley Davidson Fat Boy 1993 Suzuki GSX600F - Rebuilt 1995 Harley Davidson Chopper build from ground up. 1983 Yamaha XJ900 REBUILT! ![]() 1971 Triumph Daytona 500 - Restored 1987 Yamaha FJ1200 |
There should be some kind of warranty on it still?
Sounds like an exhaust leak.
2016 CSC RX3 Ginger Edition Check out my blog here: https://www.facebook.com/My-CSC-Zong...0302595973417/ |
Duh! I totally forgot about those soft-clay-like-bolts that hold bolt the exhaust to the engine. It sounds like something major is wrong, but no, it is a bolt... Simple fix is to tighten them--slightly harder fix, and risks breaking one of them (the one that isn't loose) when you remove it, is to replace them with better bolts!
And I was sure everyone here would say stuff about valve adjusting.... The sound isn't very strong in reality, the higher edge (the sound I'm concerned about) is stronger in the vid cuz I put the camera really close to it. It's coming from inside the engine. I'll check the bolt connecting the exhaust . Maybe it's that, I wish. Thanks all
Did you begin your xcountry trip? If you are doing long stints at high speed on this bike I think it's best to keep it between 50 and 55 miles per hour on the GPS. It is tempting to go wot since is is a good runner. The mph indicator is totally wrong. By the way from my experience. Hope it works out!
#10 | |
#11 |
I feel another video coming on
![]() Main worry is the valve cover.. looks pretty tight in there. I'm off today, I might fire up the shed heater and see whats needed.
#12 | |
Here's a pic of what to expect if you haven't adjusted the valves yet. Seriously easy access. I go TDC compression stroke, Intake - .05mm and Exhaust - .08mm. Evelyn - when you do check the exhaust header bolts (or nuts, whichever the case may be), loosen the entire exhaust system all the way back first, to give you the "wiggle room" to make sure the exhaust header is flush with the head before tightening them down, then tighten the rest of the exhaust on back to the tail of the bike.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 08-29-2016 at 10:54 AM. |
#13 |
Nice clear shot.. Thanks 2LZ.
![]() ![]() ![]() https://www.youtube.com/watch?v=PnpI9ObYYVo"
2014 Bashan Storm 250 Enduro 1998 Harley Davidson Fat Boy 1993 Suzuki GSX600F - Rebuilt 1995 Harley Davidson Chopper build from ground up. 1983 Yamaha XJ900 REBUILT! ![]() 1971 Triumph Daytona 500 - Restored 1987 Yamaha FJ1200 Last edited by dossbag; 03-18-2016 at 03:43 PM. |
#14 |
Thanks everybody!! I'll tell you how my valves looked like.
That vid explained a lot to me thanks Jeff |
#15 |
I ended up going with .05 and .08 for a couple reasons. One, I read it somewhere but yes, most say .05 and .05. What I DID find after a number of valve adjustments is that the exhaust valve has a tendency to always be tighter than the intake when it wore between adjustments (probably due to the greater heat)....so I went with the .08 on the exhaust to help offset that wear a little between adjustments. I'm sure they're fine either way. The lash is so tiny anyway...
