Old 03-20-2016, 12:31 PM   #1
fitze   fitze is offline
E85 fuel
Has anyone tried to make a motorcycle run on just E85. Someone asked me and I don't have the answer if it can be done. He wants a pit bike or dirt bike running E85
I kind of think it's a dumb idea because of the lack of filling stations.
Maybe start with EFI not a carburator? I don,t know.
Any help/info would be appreciated.
Old 03-20-2016, 12:54 PM   #2
Azhule   Azhule is offline
It's going to take some of work...
Look on Youtube, people have been converting all types of EFI and Carburetor Engines to run on E85 "Flex Fuel".
https://www.youtube.com/results?sear...e85+conversion
He would have to do similar things just apply it to his motorcycle
Old 03-20-2016, 06:44 PM   #3
dgil692014   dgil692014 is offline
Send a message via Yahoo to dgil692014
dont run E85
E85 in these machines will ruin the rubber in the carbs, plus cause massive corision in the metal carbs. I run 100 oct avation fuel in all my small engines. its a better fuel and costs only 3.89 a gallon by me .
Old 03-24-2016, 04:13 AM   #4
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
It can be done, it'll be a pain in the butt,and there is no benefit to it. E85 is about 30% less efficient therefore requires 30% more fuel but it is not 30% cheaper. The only gain would be slightly better torque but in our engines it wold not be noticeable. E85 is only beneficial in forced induction applications where it's higher octane makes it a cheap alternative for $26 a gallon race fuel.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 03-24-2016, 05:34 PM   #5
Only downside other than the extra $ and inconvience is the lead will foul the plugs so they may need more frequent replacement, no biggie.
I have alcohol in gas. I view it as a contaminent.
I had to have the fuel pump of my car replaced. The alcohol ate its seals and my wallet.
Old 03-24-2016, 06:03 PM   #6
Louis Angel   Louis Angel is offline
Louis Angel's Avatar
Yeah. What he said.
" If it ain't broke, I can probably still fix it!" ---- Tim Allen
Old 03-24-2016, 08:23 PM   #7
jct842   jct842 is offline
As a matter of fact it is probably worth at least 50 cents a gallon more for small engines to use real gas over crapahol going with its lower mileage and the long term damage it does to engine and fuel components. Larger engines deal with it better than do our bikes and then the lawn equipment every year that is sent to the recycle bins due to what crapahol did to the carbs. Crapahol keeps small engine shops in business even in today's throw away society.
Old 03-24-2016, 09:26 PM   #8
TXDSRIDER's Avatar
And the lead will clog your cats if you have them and o2 sensors will be destroyed over time.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 03-24-2016, 09:29 PM   #9
TXDSRIDER's Avatar
Unfortunately here in Houston we do not have 100% gas available.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
2002 Buell Blast
2000 Kawasaki ZR7
Old 03-25-2016, 04:26 PM   #10
katoranger's Avatar
I run all my small engines and the premium no ethanol gas. Tractor is going up to the station tomorrow to get filled.
My Yukon is E85 compatible. It has less power and gets about 14mpg on E85 compared to 19-20 on E10 gas. Typically E85 is not cheap enough to overcome the mileage difference.
Old 03-25-2016, 06:04 PM   #11
Hard data, THANK YOU ! That's what I have always heard about alcohol fuel, less btu's. So it's cleaner burning...., but have to burn 1/3 more to go the same distance, what's wrong with this picture? GOVERNMENT MANDATES ALWAYS HAVE UNINTENDED CONSEQUENCES.
Old 03-28-2016, 06:28 AM   #12
bogieboy's Avatar
*snip* Crapahol keeps small engine shops in business even in today's throw away society.
yessir does it ever...lol!!! i get sick of seeing the blue fuzz and corrosion in all the carbs this time of year from crapahol where i work... but hey at $35 for a carb clean we make out ok...LOL
Old 03-29-2016, 08:24 AM   #13
katoranger's Avatar
I filled up in Dodge City, KS. With the wind blowing behind us I got 24mpg. Regular E10 gas.
We run E85 when the weather is warmer and the price difference is wide enough. Has to be about 60% of the regular to come out.
In the cold it starts hard an runs rough until the engine warms up. I tried it at Christmas time in MN. E85 was 1.02/gallon. About 3 below.
Old 03-29-2016, 08:27 AM   #14
katoranger's Avatar
My new Stihl products have never seen any ethanol. My mower sat all winter with Premium ethanol free gas in it. Started right up and mowed the yard.
Old 03-29-2016, 09:18 AM   #15
BARLOW   BARLOW is offline
BARLOW's Avatar
when i was building brigs engines for my race carts, i only had to change the jets to go from gas to alcohol ... jets had to be about 2x the size as gas and as you may guess, it used about 2x as much but made mad power over gas ... had to change oil every time you ran it though
