Old 04-03-2016, 12:57 PM   #1
qwert   qwert is offline
Weird one... Indicator won't stop flashing
Bike has been in garage for about a month. Came to ride it today and as I started up the right indicator wouldn't stop flashing. Indicator switch looks OK and feels normal. If I indicate left then they both flash. Could the switch be broken or is it a more serious electrical problem?
Old 04-03-2016, 01:07 PM   #2
willy dog   willy dog is offline
willy dog's Avatar
new to bikes with automotive problems it is almost always the flasher relay
Peace and Zong Life
Old 04-03-2016, 01:49 PM   #3
I think Willy Dog is correct. I suggest you try another flasher relay which is LED compliant.
Old 04-03-2016, 06:12 PM   #4
Jay In Milpitas's Avatar
Electro logic.
Let's think this through, qwert. The flasher only starts and stops the electric flow, it does not know or care where it goes from there.
The turn indicator switch sends the signal to where it's supposed to go.
If your Honley has a 4-way/emergency flasher switch, it will send that same signal to all four points.
As long as there has been no damage to the wires (mouse chewing the insulation) the logical starting point for checking is the switch assembly. Open it up and have a look.
Good luck.
Old 04-03-2016, 10:01 PM   #5
Eco Mouse   Eco Mouse is offline
Eco Mouse's Avatar
Blinker Fluid is low... duh...
Old 04-04-2016, 02:25 AM   #6
Thanks guys, so I think I've just made things ten times worse. I took apart the switch to have a look and while removing a couple of screws a small spring and piece of metal jumped out. I have no idea how to put it back together now. If anyone randomly has a photo of the inside that would be incredible.
It's all learning I guess but we actually have nice weather here in the UK at the moment so I want to get out there!
Old 04-04-2016, 12:26 PM   #7
All sorted. Managed to get the switch back together after a good clean. Working fine now. Thanks!
Old 04-04-2016, 03:50 PM   #8
Good for you. I was just about to take a photograph for you.
