Hawk 250 Issues...Carb? Fuel? Air Leak?
So after replacing the stock carb w/30MM Mikuni Carb and running only high octane fuel, I had a failure yesterday and had to walk my bike 5x miles....Full tank, ran fine prior to leaving, standard RPM's...She started sputtering so I killed it to investigate. Then I could not get it re-started, ugh..I have't pulled the plug to see if it was fouled because it was getting dark by the time I got home. I know that's where to start.
Now, I am no expert in this field and any help would be greatly appreciated. ![]() |
#2 | |
I still have a filter I need to put on my fuel line ![]()
As mentioned above: "Still have a filter I need to put on the fuel line"... does your bike have a Fuel Filter attached to it Sebastian?
Either way, if it does or doesn't; I would pull apart the Carburetor and give it a good cleaning, from the sounds of it; "was running fine, started sputtering, then died/wont re-start"; it would lead me to believe the carb got itself clogged with something. I use this K&L Carburetor Wire Cleaning Kit to poke out all the microscopic holes. ![]() I can take and post up a few pics of the few places that usually get fully plugged/clogged... or... I'm sure you can find a few YouTube videos with help on the subject ![]()
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
first thing I'd do is pull the fuel line, turn on the petcock and be sure fuel is flowing. Second is check the plug/spark. It's SO easy to pull these carbs and give them a quick cleaning, I'd probably do that. when you do, be sure to remove the slow speed needle during the cleanout. Not that it may be your problem, but I didn't do it the last time I had a problem and ended up doing it again.
Azhule has a great point with the cleaning kit, I was able to just use compressed air and blow things out. since your carb is pretty new, I gotta thing that gummed-up isn't your problem. either way, good luck with it. |
FIRST OFF, Was the gas on? I know it seems like a dumb question but.....
My YouTube channel where you can check out my hawk and other cool stuff: https://www.youtube.com/c/Andrew93 newrider93 AKA Andrew93 |
Yep Check fuel flow first then check spark before you disassemble anything.
BTW, that carb cleaner is identical to a welding tip cleaner, which is available at any shop that sells welders. Might even be cheaper.
