Hawk: make starter work when not in neutral
Has anyone already defeated the neutral safety? If so, care to share how?
Mine will start when its not in nuetral and the clutch pulled in, does yours not?
It was simple to do on my Bashan (WILL 200) and Kawasaki (KLR 650), however I never share this type of info with people for a few reasons...
1) it's already been covered several places all over the internet... and the biggest reason I encourage everyone else to 'also not give this kind of info' is... 2) I'm not about to get blamed/sued for any "safety switch bypass accident"... It's easy to do and the info is out there and just as easy to find... just apply the knowledge from one of the "big 4 brands" to your "China Bike" if you want to bypass those safety/annoyance switches.
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
Every other bike I've owned either had no safety or it was tied to the clutch, not neutral. This is a first for me.
Hmmm.. i dont think im understanding correctly. Your saying your bike wont start if its in gear?
Typical E-start is like http://postimg.cc/image/xsmoa2093/
--- How to bypass, i won't tell the details...
#7 | |
I guess I'll have to trace it out myself, was hoping someone would be able to say which color wire I need to disconnect and connect to a constant power source. |
#8 | |
I will mess around with mine tomorrow morning, is it possible a bad clutch switch would do this? Or maybe the wiring isn't connected properly? I could see if the bike doesn't know that the clutch is pulled in, it wouldn't let you start until its in neutral. Try shorting the two wires that attach to the clutch lever and see if it will start. Ill see what I can gather tomorrow from my bike. |
or is there a relay to jumper?
#10 | |
#11 |
Hopefully, this will be one of those "DUH" things.
#12 |
well, screw waiting for tomorrow. Sure enough, there is a clutch switch and it is open no matter what, no continuity.
#13 |
Hopefully!
![]() These are the wires: ![]() |
#14 | |
![]() I was thinking about ordering these: http://www.ebay.com/itm/Pair-All-7-8...3D172046665131 |
#15 |
If I were to upgrade, I'd upgrade to a hydraulic clutch.
