#3 | |
John P. 2016 Hawk 250 - Black All my mods are documented on my Blog! My Blog | Google+ | Twitter | Facebook |
wouldn't the the PCV system need to be hooked to the intake? If not it's not going to have the positive pressure I would think.
Those are the ones if you get them make sure you also get a can of UNI pre oil. and you will have to do a re jet and use a quality exhaust.
No I've used these time and time again & never had any problems.
Retaining a PCV system is ideal. Air box mods generally require a re-jet, assuming the mod actually changes air flow. Doing the mod to a pod filter may or may not add power, but will definitely add noise. There is no requirement to combine it with an exhaust system as someone else stated. Combining the two should bring the best performance, but neither is dependent on the other.
If your seeking (performance) just use the UNI filters UP-6182AST 1 3/4 ID x 6" HGT & UNI UP-122 3/8 Breather Filter, but as I stated you will need to perform a (rejet) & either (change the exhaust) or free up the stock one. Trust me I've Been in the motor sports industry for 17 years. I need to mention I'm a speed freak & some mods I do & or use are extensive & you may not be willing to do the mods to your bike that i would do to mine.
I have a new exhaust coming and a mikuni carb as well.
I am going to try to rig up the pcv to the intake. |
#10 |
not sure who is saying what, but look at it this way, assuming the engine is tuned correctly balanced from the factory,simply put, if you improve the breathing at the front, you need to similarly improve the exhaust flow at the rear. more power comes from burning more fuel, at an optimal stichiometrically correct ratio. more fuel air in/ more fuel air out.
#11 |
I've installed several of these, with good results: http://www.ebay.com/itm/BLACK-42mm-B...FUi8Cu&vxp=mtr
#12 |
Phrase of the day folks, we have a winner.optimal stichiometrically correct ratio
#13 |
Sure as hell is a blue ribbon winner
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
#14 |
you guys are killing me,,
#15 |
Come on Seer fess up ......stichiometrically was on your desktop word of the day app/calander recently
