Carb Adjustments
Okay so I know trying to troubleshoot over the internet is less than optimal and very open to interpretation but you guys have been able to point me in the right direction on other problems so lets take a crack at this.
So first my setup:
Problem: Bike idles, sharp response if you crack the throttle while idling, runs good wide open. Problem is at partial throttle bike sluggish, back fires, coughs through carb, hesitates. When decelerating it back fires sometimes pretty good. So I've been playing with the idle fuel screw thinking the bike is running too lean but the more I read I think I'm not attacking the right issue. By adjusting the idle fuel screw I'm just making the bike idle to rich but not correcting the issue at partial throttle. I'm thinking I need to set my idle back and increase fuel at throttle but since I'm already at the bottom groove I need to add a washer and raise the needle a little more. Does any of that make sense? Or have I been staring at this too long and not thinking straight? Here is how the plug looks after a run, it was clean.
2005 Kazuma Cheetah 200 (Swamp Thing) |
So reading more and wondering if my CDI might be heat damaged? As you can see mine had been sitting on the pipe for a while, not too mention it's 12yrs old and was left to sit outside unprotected. So ordered CDI, Coil, Rectifier and relay kit from Amazon.
Swamp thing presents...
#4 | |
Ariel I actually saw where you posted that in a different thread and it's what helped me get my head around it. So I think my plan is after I get the new CDI and coil on I'll try adding that washer. Because like I said I'd idles good, runs wide open good it's that in between where it falls down.
#6 | |
#7 | |
You're welcome!
