Water cooled cylinder kit?
Is this for the 167FMM, it says CG250. It appears to be a kit to switch over to water cooling.
https://www.aliexpress.com/item/Wate...e-e5bedee23b0e Although, I'm not sure how much better it would be than adding and oil cooler to the 167FMM. |
Looks like it's just the replacement cylinder for the water cooled version. My bad, delete this post please mods.
Doesn't mean that a CG couldn't be converted to water cooled. I remember seeing CG motors near the 270cc mark on Taobao, so perhaps a Frankenstein could be created. You'd need whatever water pump and associated engine cover, but it's worth discussing. A water cooled motor could tolerate higher compression, which is where the real benefit comes from. My Kawi KLR250 is between 24-28hp (depending on whom you believe), and that's a long way from a similarly sized air cooled motor.
