Old 01-01-2017, 06:56 PM   #1
TT250 swingarm lube
On a rainy day it's prime time to do garage stuff. Checking the swingarm on my TT250 sounded like a good idea. This is a new bike so I'm just establishing a baseline. The CSC tutorial is perfect, take a look and you know exactly what needs to be done. I'd rate this as a 1 hour job.
OK, the swingarm and shock pivot point are not needle bearings. They are all bushings. Mine had some grease so I just added a bunch more. More is better in this case. The factory had done a decent job, I just added more and gained a bit more confidence in the the bike.
While I was at it, I took both the swingarm bolt and the axle bolt over to my lathe and added a center punch so now I can accurately measure the swingarm to axle length.
Peter Y.
Old 01-01-2017, 09:22 PM   #2
Mine varied from "some" grease to "almost none". Good idea to do this project when it's a no-ride day.
Old 01-02-2017, 03:27 PM   #3
I like the center punch idea. Did you punch both ends of the swingarm bolt?
Old 01-02-2017, 05:24 PM   #4
Weld, yes...both ends. The axle already had a center punch on the threaded end, I only had to do the bolt end. Now I can accurately measure to make sure the swingarm bolt and axle bolt are parallel.
This homemade tool makes measuring a snap once you have the center punch in each axle.
I have done the same mod to my RX3.
Peter Y.
Old 01-03-2017, 11:00 AM   #5
My next question was going to be about the best way to measure between the swingarm bolt and the axle, but you answered that for me.
Old 01-03-2017, 11:24 AM   #6
OUTERLIMITS   OUTERLIMITS is offline
I would go with something like this. Very simple and you could take it on the trail with you if need be. They are made by a couple of different companies, Motion Pro being one of them.
Old 01-03-2017, 11:49 AM   #7
Sullybiker's Avatar
You can also use a ruler (metal one is best, but any will do as long as it is stiff and straight).
Position it against the inside of the side plates on the rear sprocket at about 45 degrees upwards, then gently rotate the tyre and see where it lines up on the chain as you move it toward horizontal.
Old 01-03-2017, 08:03 PM   #8
I think we have about 100 years of experience with getting the chain aligned so whatever works for you is OK with me. My method works best for me in the garage, on the road I'll use the Mark 1 eyeball.
Peter Y.
Old 01-03-2017, 10:08 PM   #9
'16 TT250   '16 TT250 is offline
Once torn appart, any reason to not add zerks so you can give it an occasional shot easily? I haven't looked into the swingarm at all so no clue how easily this could be done.
Old 01-04-2017, 08:15 AM   #10
I would and I have. Gives me a peace of mind knowing it is greased up. Beats the hell out of pulling the swing arm bolt to grease it and most of the grease gets wiped off when you reassemble. Fill it till it just starts to ooze out.
2004 Honda ST 1300
Old 01-04-2017, 02:49 PM   #11
BlackHawk   BlackHawk is offline
BlackHawk's Avatar
How about some pics and more info on how/where you installed grease zerks. My swing arm was dry as the Sahara when I pulled it and I really like the idea of being able to hit it with the grease gun.
Old 01-04-2017, 03:16 PM   #12
Drill, Tap and install grease zerk. use a bottoming or plug tap if you don't want to remover the swing arm bolt. Dip the drill bit and tap with grease to collect the metal shavings. The tap is on the bottom for easy access of grease zerk.
2004 Honda ST 1300
Old 01-04-2017, 10:23 PM   #13
Pic didn't work on my end
Old 01-05-2017, 08:50 PM   #14
BlackHawk's Avatar
Thanks, Great Idea!
This just went on my mods list!
Old 01-06-2017, 07:52 AM   #15
Stiff and Straight... I think they make a pill for that!
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
