TT250 carb options
Would like to go with a carb that has a proper enriching circuit, not choke. This would be for top end performance. Want to retain the stock airbox. Also looks like the engine end of the carb has a flange, not a spigot, what options work there?
Does anyone have a link to a carb that is "bolt on" or nearly so? Genuine (japanese) Mikuni or Keihin are desired. Thanks, Mike. |
Hey, Mike. You could try a CV carb, which is typically found on GY6-based engines. They have a minor delay due to the vacuum slider, but they have a proper enriching circuit. You could try this for mounting: http://www.ebay.com/itm/Mikuni-Rubbe...dYEBEF&vxp=mtr
That one might be too big, I think the bolt holes on our most of our Chinese engines are only 48mm apart, the item linked above is 57mm between bolt holes... I would check all sizes on your bike and email the seller asking for sizes before you make any purchases
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
was thinking the same thing.
Very good point; I failed to consider the bolt hole distance. Nevertheless, there may be an adapter out there that would allow a spigot-mount carb on a flange.
