Looking forward to weekend ride: Maintenance Questions
Hello all, I have a few questions:
1. I read on a DS setup thread on this forum, to replace the spark plug wire. Will this work: https://www.amazon.com/gp/product/B000GU0Z9A/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX 0DER 2. Perhaps wishful thinking, but I was hoping for a Zerk to grease the rear axle. Dumb thought right? Is it pretty much the same procedure then for greasing the front tire: remove axle bolt, apply grease to axle bolt, re-install axle bolt, make sure wheel is straight and chain tight. Is there a thread or video on this? 3. Chain replacement. I'd like to order a new chain just in case the stock one is crap. What chain do I get? I know I have a 46 tooth rear sprocket. Would you also need to know the front sprocket teeth count in order to know what chain to get? Would this one work? https://www.amazon.com/RK-Racing-Chain-428SO-130-Connecting/dp/B004ZG7X14%3FSubscriptionId%3DAKIAJZ74L6MCPARTLKTQ %26tag%3Dhawk250-20%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165 953%26creativeASIN%3DB004ZG7X14 thanks |
I believe the "spark plug wire" is one contingent thing, paired with the ignition coil. Never had to replace it so I personally do not know. Here's what you'd be looking at:
https://www.amazon.com/Chinese-Ignit...+ignition+coil I have the same chain with a 16/44T set up, you just measure the chain, there's a systematic way of knowing how many links to take off, but I forget. I think I ended up taking 4-5 links out. I'm sure a couple of the more experienced individuals will chime in
2015 Hawk 250 ~ Aftermarket Exhaust/K&N/LED everything/16/44T/Shinko 705's |
I put a grease zerk on my swing arm. I pump it full of grease mostly to keep any water out when I go off roading. I do run through deep water and mud with it.
Unibear make a good chain. Your stock chain may be 130 link. https://www.amazon.com/dp/B01ACMEZCE...I3JSP25IAKW4M1
I dropped the entire "Made In China" Ignition Coil and Plug Wire set-up on our Bashan... no more weak and intermittent spark issues
Coil on Plug anyone? ![]()
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
#6 | |
Found Information: A little pricey but will be a lot better than coil and wire. Thanks Azhule for posting. ![]()
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 03-16-2017 at 04:46 PM. Reason: Found Information |
#7 | |
This is the chain I put on the TT250 and I now have these chains on all of my rolling stock, I was so impressed with them for the price. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Taken from a motorcycle... bought a 4 pack set on eBay, complete with the wire harness for under $70 a long while back... originally bought it for my KLR 650... and found out they work on the China Bike just as easily...
They are usually about the same price all the time on eBay or a Pick and Pull Junk Yard... 60 to 100+ $$ for a 4 pack... most of the time they show up with the connectors being sold separate I still have 2 left sitting in a box if I (or anyone) ever needs them
#9 | |
#10 | |
#11 | |
The 128 link on our TT250 runs a 17 front and a 47 rear and has lots of adjustability. Best just to count.
#12 |
That was me when I counted the sprocket, and I only had to count to 46!
#13 |
My hawk came with a 130 link but removed 2 links when I switch to the 40 tooth sprocket. 128 may be okay. get busy counting.
#14 |
Lotsa guys on here have switched to Uni-Bear Chain, and I've never heard a complaint....ARH
#15 | |
