03-23-2017, 07:46 PM | #1 |
Hawk 250 bent fork?
I have a 2015 hawk 250 I laid it down trail riding a couple weeks ago going about 15 mph. After the fall the handlebars were crooked so I went home and loosened the bolts on the lower triple tree wrenched it straight, tightened it and thought all was well.
After a couple miles I found they went right back to where they were. Going back and looking at the nut in the center of the triple tree it was loose and way out of adjustment. Adjusted it so it was snug and loostened the lower triple tree tightened the 30 mm nut on top and straightened the wheel and tightened it all back up. After a quick cruise it seemed all good and rode straight. A couple gravel roads later it's crooked again I've done this a couple times now and it keeps going back to crooked. Is it my forks? Could it be the triple tree? Any other ideas? I have to assume it's probably the forks. Does anybody know of some other brand forks that would fit? Or even a whole front end? The whole front end could get speedy but might be worth it |
03-23-2017, 07:55 PM | #2 |
Without seeing it in person ,or at least several good quality pictures ,it could honestly be just about anything .Since it's truly a safety issue , get it checked out by a competent bike shop .
03-23-2017, 10:18 PM | #3 |
03-23-2017, 10:40 PM | #4 | |
03-24-2017, 01:43 AM | #5 | |
03-24-2017, 06:02 PM | #6 |
The wheel does not sit in the middle of the forks unless I just did the adjustments. I did the adjustment again to make it straight again except this time I did loosen the axle nut and did it in the order ARH recommended and after a short test ride (it's cold here) it seems to be shifting back to crooked again.
03-24-2017, 07:45 PM | #7 |
have you put a straight edge along the forks to see if there is a bend.
if there is a bend it will normaly be just below the bottom triple clamp..
03-24-2017, 07:47 PM | #8 |
try this loosen the 4 bolts that hold the shock and twist the shock 90 degrees then straighten as befor. if it doesnt work try twisting the other one.
