Old 03-24-2017, 06:50 PM   #1
jsumd   jsumd is offline
jsumd's Avatar
Vader issues
Ok so everything was great and i changed to the recommended led headlight bulbs. The thing keeps blowing fuses. The dash will come on without the key in and then blows the new fuse. Im terrible at electrics and dont know where to start. I changed back to stock bulbs and same thing.
2002 Harley Davidson XL883R
2012 Yamaha FZ6
2022 Hawk 250
2002 Yamaha R6 *sold*
Vader 125cc *sold after owning for many years*
1997 Jeep Wrangler *sold due to frame rot*
Old 03-24-2017, 08:58 PM   #2
Someone had this exact problem not too long ago--I think he went through all the wiring and had to find his short. Look through this section to see if you can find the thread.
Old 03-24-2017, 09:00 PM   #3
jsumd's Avatar
I looked at that thread and mine worked fine up until the point i changed those bulbs. I'll still give it a look but it just seemed odd to me that it was fine and then not.
2012 Yamaha FZ6
2022 Hawk 250
Old 03-24-2017, 09:52 PM   #4
On my TGB scooter, I had an issue once I pulled my rear bulb since it had shaken itself loose from the time I purchased it to the next week I got it home and tried to start it. It kept blowing fuses. What it was, once I unbolted the rear light assembly, the metal bar that is the ground had moved and was laying across the other bars. Normally, the bulb physically pushes the ground out of the way, but for some reason, when I originally took the bad bulb out, the bar moved and was pushed across the other metal bars. When I put a new bulb in, it pushed the ground across the other bars and caused the short, time and time again. It needed to be bent back into shape. See if where you took the bulb out, everything is where it is supposed to be, or is it bent out of shape and the ground had moved. I know I am not being clear, and wish I had photos to show you, but if it is not the wiring, it could be the bulb assembly.
Old 03-24-2017, 10:05 PM   #5
jsumd's Avatar
Thanks so much. I'm giving it a break for tonight and I'll get back on it in the morning. Surely I just messed something up when I changed those bulbs around. I also accidently put in the wrong fuse when i first changed it. It got mixed in with the correct ones. It got really hot then blowed. I hope I didn't mess more stuff up. Kinda bummed out since I haven't even had the thing started the first time. lol
2012 Yamaha FZ6
2022 Hawk 250
Old 03-24-2017, 10:19 PM   #6
jsumd's Avatar
I've been messaging with the guy that had a similar problem and apparently there is another fuse which is a blade type. I haven't been able to spot that one. Maybe he will get back to me on that.
2012 Yamaha FZ6
2022 Hawk 250
Old 03-25-2017, 08:38 AM   #7
jsumd's Avatar
Ok, so I think my problem may be very simple but I hate to say it and jinx it. The manual said it's a 5A fuse and i took it's word for it. When I found my old fuse it says 250 A on it. So I'm assuming this is a 2.5 A fuse. I hope that's all it is.
2012 Yamaha FZ6
2022 Hawk 250
Old 03-25-2017, 09:50 AM   #8
jsumd's Avatar
Fixed. When i put my bulbs I crossed one of the connections inside the bulb socket by pushing too hard.
2012 Yamaha FZ6
2022 Hawk 250
Old 03-25-2017, 11:55 AM   #9
Great! Like I mentioned, my TGB had a similar issue which seemed bigger than it was (it kept blowing each new fuse I put in, one after another).
Old 03-25-2017, 01:34 PM   #10
jsumd's Avatar
Thanks for your help! Glad it wasnt something awful.
Now im trying to solve another issue. My tire is rubbing the exhaust. Lol
2012 Yamaha FZ6
2022 Hawk 250
Old 03-25-2017, 02:42 PM   #11
That one isn't too bad--I mean, it is Chinese after all
I haven't kept up with all the details regarding Maxipad, but I am sure most problems with the Vader, he has come across and resolved? You can try PMing him, or find him on youtube.
Funny thing is--when the Chinese enduros were new in the early to mid-2000s, which is the major reason this site was created, there were many 'mystery' ills and issues with those, and look how far the enduros have come. These minis shouldn't take as long to evolve, but I am guessing the solutions to the issues are 'right there.' Like some of us were back in the day, you guys with the minis are the 'pioneers' with them--and believe me when I say 'you guys' have it much better than we did!
Old 03-25-2017, 09:08 PM   #12
jsumd's Avatar
Doh!
It helps when you put the shock in instead of the way it was shipped
2012 Yamaha FZ6
2022 Hawk 250
Old 03-25-2017, 09:54 PM   #13
I guess when there is no manual, you are assembling it 'hit or miss' style!
Old 03-25-2017, 10:13 PM   #14
jsumd's Avatar
Exactly! I've never assembled one before so i was learning as i went.
2012 Yamaha FZ6
2022 Hawk 250
