04-25-2017, 08:52 AM | #1 |
Vader 125cc Valve adjustment
Hey fellow Vader owners. I've been having trouble on getting my bike started right out of the box. My guess is after the tinkering I've done it probably needs a valve adjustment. I've never done one before but I have the tools and the confidence. I'm assuming its very similar to the grom? Does anyone know the valve clearances?
04-25-2017, 08:57 AM | #2 |
Also any other tips would be greatly appreciated
04-25-2017, 04:23 PM | #4 |
I'm assuming I have spark and fuel flow as it sounds like it wants to start. Would compression be an issue right out of the box? I dont have the tools to check compression. I know the throttle cable has a bit of slack but it doesnt seem like enough to prevent it from running if I'm pulling on it. Haven't tried starting fluid either. I think I'm going to check the valves, change the oil, and take it from there. My new carb and stuff are showing up soon, that might help, although I was hoping to break the motor in before the swap.
04-25-2017, 05:35 PM | #5 |
Success! I was only able to bump start it, but that was enough to warm up the oil for a change. I think the regulator is junk (it buzzes when I try to use the electric start). Tomorrow I'm going to do a valve adjustment and mess with the carb a bit. It deff smells like somethings burning, cant tell if thats the shitty oil or a hose touching the engine or something like that. Speedo doesn't work, need to check the connection. Baby steps I suppose.
04-25-2017, 06:30 PM | #6 | |
04-25-2017, 09:30 PM | #7 | |
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
04-25-2017, 10:22 PM | #8 |
yeah, mine definitely had that weird smell the first time it ran. Kind of like a mixture of melting plastic and oil and exhaust.
