11-21-2007, 04:07 PM | #1 |
Help, Bogging
My lifan gy-5 is bogging... Can anyone help please?
11-21-2007, 05:27 PM | #2 |
New bike? We need some more details.
Allen
11-22-2007, 12:33 PM | #3 |
No its not a new bike I have had for about 7 months, it has 830 miles... I will take off and it"ll makeva gurgling sound and start bogging. My Dad and I were thinking there could be trash in the fuel line or someting? Any Suggestions?
11-22-2007, 07:32 PM | #4 |
Is the spark plug wet or dry after it acts up??
A gurgling sound like its flooded out?? if its flooding out I'd pull the carb off and give it a good looking over?? Have you done regular maintenance like clean the air filter and keep the valves properly adjusted?? If you think it is a carb problem start by verifing fuel supply to carb. turn off the fuel valve and pull the fuel line off the carb and place that end in a clean glass container and open the fuel valve and let it run for a few minutes to verify you have a good/constant fuel supply from the tank. If the fuel runs a bit then slows or stops take the fuel cap off and let some air in the tank and if the fuel starts flowing you have a plugged vent on the cap(it happened to me and someone else) If you have a good constant fuel supply from the fuel tank then you may want to pull the carb off and take the float bowl off and have a look inside. If there is dirt/debris in the float clean the carb and tank and install an inline fuel filter. |
11-22-2007, 08:07 PM | #5 |
Alrigth I will try that, Thanks!
