zong sierra, should i move carb clip after mods?
Hi,
I bought the bike new and rode it for several years then I let it sit for a few years outside without cranking it. I moved twice since then with the carb off and lost a lot of parts. Well I've got it back running but it runs bad. I have to many problems going on to check plug and it tell me anything right now. before replacing o-ring it runs with choke on but pops a lot. Anyway today I found an o-ring to replace the pinched manifold o-ring and I replaced the choke/enhancer with the pullout one that's for the Yamaha carb not the thumb one for the zong so I shouldn't have anymore air leaks. I have the fmf tc2 muffler and now I replaced the airbox with a cone filter. I have the carb apart and I'm tired of pulling the carb and fooling with it. lol After it sit for a few years the needle seized up and would not move in the carb. I found a used parts carb on ebay and now the carb is clean and ready to go back together. Just want to set the clip now while I have it out. the new needle has the clip in the middle. should I move it down one? I'm in northeast ga and at arould 3300 above sea level. thanks guys for the help in advance.
Zongshen Sierra Mods: knock off DRC Edge II Taillight , FMF Turbine Core 2 Silencer, Halogen bulb, 18" Wheels, Real Tires |
I cant remember if I had moved my old clip and cant find it anywhere now anyway. I have been reading older posts but not sure how much my sea level changes things that other people did.
A few pix
This is now
#5 | |
Thanks,
It's the factory carb tv28 with factory jets. I had so many things wrong going on it I'm just trying to decide should I move the clip before I put it back together since I just deleted the air box and added the cone filter.
There is no way the factory jets will work satifactorily with a cone exhaust and a pod air filter...ARH
Thanks, mine says 132. Is that factory? I put the fmf pipe on so many years ago I'm not sure if I changed the main jet or just moved the clip or both. I know elevation matters just not sure how much. I read so many posts I didn't find The right one and didn't check the one in my carb till now.
Never mind, the 132 is stock
#10 |
It ran great with the 132 in it and fmf pipe for years but now I have the cone filter I guess I need to get some more jets. I'm gonna put it back together and see what the plug looks like and if it how it runs l. I dropped the clip down one, it was popping last I ran it.
#11 |
ariel,
thanks for your help, It still wont idle but I went as far as I can go without jets. I made sure the float was perfect. it still wont idle without some choke on. runs good but pops a little but will barely idle and is with screw out about 4 turns. carb is clean and gas is thick with seafoam so I guess I need to order some jets and go from there. thanks again, alan
#12 | |
#13 | |
#14 |
Start with fresh fuel.....seafoam can and will lean out your mixture to the point of not running well.... no sense in tuning to run with a crapload of seafoam, only to find the next tank pig rich... been there donrle that with customers lawnmowers.... seafoam isnt a miracle cure like most believe...LOL
#15 |
That is a Teikei Carb similar to my Ssr. The stock jet for my 250 was a 128 and I run a 132.5 now with modified exhaust and intake and it runs great. If I move my needle up more than 1 shim I have stumbling on deceleration and it is just way too rich.
If this carb gives you any more problems consider just getting a new one on Taobao for a around $10. Reference the qingqi qm250 while shopping.
2013 SSR XF-250 |
