Old 09-15-2017, 03:52 PM   #1
NotTheRealMVP   NotTheRealMVP is offline
Oh No Hawk 250 Speedo Cable
Unfortunately I never payed attention to tightening the speedo cablefor quite a while, and it eventually came loose, got caught in the spooks and ripped the entire thing off.
However Ive been having some trouble finding a replacement.
Finding the inner cable is the easy part, but finding the correct outer housing has been difficult.
Does anyone know the part #? or similar cable + housings that actually fit the 2016 Hawk.
The only success in even finding one has been on RPS's website, but Im trying not to pay 45$ for the speedo cable.
Both attachment points at the wheel and the speedometer are untouched and undamaged.
Old 09-15-2017, 03:57 PM   #2
Edit: Does not fit.
Should be the same as the TT250 Cable http://www.cscmotorcycles.com/TT250-...-p/zt6-102.htm
2004 Honda ST 1300
Old 05-26-2018, 07:21 PM   #3
seventiesbike   seventiesbike is offline
My first post on this site.
Thanks for the tip on the speedometer cable. My daughter managed to accidentally stretch the one on her Hawk when it got snagged behind the horn. When she moved the bars hard to the left, the cable stretched and disengaged the inner at the ends.
I ordered her a new part listed on here for the TT250 risking that it will work. I ordered from the importer today (CSC) and they we're very prompt to mail it out. I'll respond here with how it works out.
Old 05-26-2018, 07:44 PM   #4
Sochin   Sochin is offline
Sochin's Avatar
If you plan to upgrade to the digital instrument cluster, better save yer dollars. it works much better and is more accurate.
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 05-26-2018, 11:37 PM   #5
Lit Hawk   Lit Hawk is offline
Lit Hawk's Avatar
The tt250 from csc does not fit. If only the inside cable needs replacing you can pull the inside cable from the tt250 and slide it into the hawks outer housing cable. Screws on end of the tt250 speedo cable are different than the hawks.
Old 05-27-2018, 07:18 AM   #6
Thanks for confirming that it doesn't fit.
2004 Honda ST 1300
Old 05-27-2018, 10:17 AM   #7
Well, darn. I knew this was a risk when I ordered it.
What I think I'm going to do is remove the inner cable and shorten the outer at the point where it got stretched. I'll use a Dremel cut-off wheel and splice the ends with a piece of metal tube. I suspect as much as 12mm shorter.
Thanks for responding. There seem to be other options in the form of kits.
I was driven off of the OEM provider by, what to me, is price gouging. They want $55usd for the cable - free shipping.
I'm a veteran motorcycle mechanic, service manager, and parts man (60s - '70s). For the most part, I perceive way to high mark-ups on the prices from the import supplier.
Edit: I shortened the outer housing about 9mm or so and spliced with a piece of tubing, similar to fuel line tubing but thick wall. Diameter of the steel coiled outer sheath is about 6mm and it was a tight fit, secured with twisted wire clamping and wrapped with black tape. Installed and works fine. I feel relieved now, a little embarrassed that I didn't check out in more detail before ordering.
Old 05-28-2018, 11:41 PM   #8
Derrickbuck   Derrickbuck is offline
Hey did you find a speedometer cable I'm having the same problem with my 2017 hawk 250 enduro
Old 02-27-2019, 10:47 AM   #9
2017RPSHawk250   2017RPSHawk250 is offline
Anybody have any solutions for finding a new usable speedometer cable that is less than $55? Bought a hawk that had it missing.
Old 02-27-2019, 10:50 AM   #10
Personally I would ditch the stock inaccurate speedometer and replace it with an accurate digital speedometer.
2004 Honda ST 1300
Old 02-27-2019, 11:09 AM   #11
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
Thats a good idea !! If you still want the old style you can have my old cable for postage. PM me. Had 200 miles on it when I pulled it off. I'm not going back...
After I calibrated my new digital speedo it was 1/10 a mile off on milage over 20 miles to the GPS. Close enogh for woods riding and speed traps
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 02-27-2019, 02:16 PM   #12
41bigdawg   41bigdawg is offline
41bigdawg's Avatar
Definitely change over to the digital speedo, so much nicer and no issues with the cable. I also have a spare old style cable and speedo if anyone needs it.
Old 02-27-2019, 02:33 PM   #13
Digital cluster also means you have a tachometer, which on its own is worth it in my opinion.
Old 02-27-2019, 10:51 PM   #14
NzBrakelathes's Avatar
I could have a couple of digital dash options hopeful;y soooon,.
Also just a speedo cable $17.50 including postage I would need a quick length tho - postage Ex China
Old 07-07-2019, 11:31 PM   #15
faraz   faraz is offline
I am new owner of Tao Tao TBR7 250 and my speedometer cable broke in 2 days. Does anyone knows if Hawk 250 Digital Speedometer works with taotao? Tao Tao does not have RPM Gauge in the cluster.
Thank you!
cable, fix, maitenence, repair, speedometer
