04-14-2018, 11:11 PM | #1 |
I should of left it stock
Got the bike was running pretty good , did the heat cycles to break it in, changed the oil, then decided to put the mikuni carb in, I watched the videos did exactly what they did and It Boggs out like crazy , have to give it gas to start it so thinking either I put it in wrong , so I actually ordered another one insane I know, same thing have to give it gas to start and Boggs our at a certain rpm I’m not to mechanical but I thought this was supposed to be easy, I put the 110 jet in the carb but I see that being done in the videos , not sure what to do here ? Does the carb just need to be tuned how do you do that ? After I start it let it warm up the electric start does work right when I push it but not after it sits a bit , I’m just sort of lost here ...can someone take the time to walk me through this I’m very frustatayed
04-14-2018, 11:16 PM | #2 |
I live inWest Haven ct and if someone is rather close I will pay someone to help me out with this, I just want to get this running at 100%
04-15-2018, 10:19 AM | #3 |
Sounds to me like you just don't have the carb tuned properly. Put a 115 main jet in it and move the circlip on the needle to the middle groove. Start there. I'm betting that 110 jet you have in there still isn't enough once the carb comes on to the Main jet circuit.
04-15-2018, 10:53 AM | #4 |
I’m not a Mikuni guy, I cut my teeth on Holley 1904 carbs* and mostly play with Kiehin VB and CVK carbs now. That said, a carb is a carb, no matter who makes it. They all do the same thing, mix fuel and air in the correct ratio so things can go bang efficiently. Carbs are not all that complicated, so most anyone on the forum can walk you through it.
We do need some more info. And yes, the carb will need to be tuned. If you need twist the throttle to start the engine, I think your needle is too deep in the main jet and needs to be raised. Bogging at in a certain rpm range is a jetting issue. Is the bogging associated with a ‘popping’ sound through the carb? That would indicate a lean condition and would need a fatter jet. Just the other way if there is no noise, the mixture is too rich at this point and a smaller jet is needed. A look at the business end of your spark plug will also help. Black and sooty, too rich. White, too lean. Should be tan in color. I would go to the Mikuni website and download everything you can about your specific carb and study it. And don’t fret about not being mechanically inclined, no one is born that way. The issue with the starter is an electrical problem, and may nothing more than a bum relay but needs to traced in the circuit to determine where the problem is located. I know that others will chime in to help, too. *Stock carb on a 1952 Ford 215 six. I’m old.
04-15-2018, 11:45 AM | #5 |
Black n sooty
I did change the spark plug yesterday and did look black n sooty , what I’m going to do first is take some pics n videos of the bogging sound and go from there ,
04-15-2018, 01:23 PM | #6 |
Mike, what engine is this? What is it in?
04-16-2018, 10:45 AM | #8 |
Sounds like it's dumping fuel. Especially now you've confirmed it has a sooty plug.
1- Is the slide in the correct way? We did have a very capable member here accidentally put it in backwards. The slant on the bottom should go toward the air filter. 2- Is the choke on in full position? Take the air filter boot off and look at it. 3- Take it off and check the float level. With two of them though, I doubt two float levels would be off to create the same symptoms.
04-21-2018, 08:35 PM | #9 |
I’m sort of going insane with the whole thing just making things worse here every time I take something off it gets worse now the battery is not charging any Ignitionis not working Do any of you guys live close to West Haven Connecticut to have some time on her hands and want to make a few dollars
04-21-2018, 08:58 PM | #10 | |
04-23-2018, 07:57 PM | #11 |
You can do it Mike. You have to take the attitude that you are learning a lot from this; not that you screwed up.
Remember the words of Red Green; "If it aint broke, you ain't tryin hard enough!"
"Its not WHAT you ride; its THAT you ride" |
