Old 04-16-2018, 09:11 PM   #1
Cravin01   Cravin01 is offline
Cravin01's Avatar
Bashan Storm Mods, YouTube link!
Here we go!
Another link to a link.
http://chinariders.net/showthread.php?t=21028
Old 07-05-2018, 11:43 PM   #2
Cravin01's Avatar
Another video link for you guys, Digital clust will soon follow.
http://chinariders.net/showthread.ph...344#post285344
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 07-06-2018, 07:11 AM   #3
tomrom   tomrom is offline
Hi, How did you get the Storm 250 sticker off? Mine seems to be clear coated over.
2017 Bashan Storm
Old 07-06-2018, 07:22 AM   #4
Cravin01's Avatar
Your right it is clear coated, I used a heat gun to get it a little hot and it peals right off.
be aware that the plastics are painted and are white underneath so don't get it too hot, I scratched a small piece of paint off trying to get the sticker to pealing on the edge. I touched up the paint with a permanent marker to hide it.
2017 Bashan Storm
Old 07-06-2018, 07:38 AM   #5
Ariel Red Hunter's Avatar
On drilling stainless steel; I was hired once to repair a stainless steel/fiberglass rudder on boat that had just sailed across from Norway. (Yes, sailed. You know, sails, those big cloth sheets they hang off of a pole?) I seeked advice before I agreed to do the job. "A lot of patience, slow speed, short bites, and Evaporated Milk." "Evaporated Milk?" "Yes, I don't know why it works, just that it does." Do not think it went easily. It took me 4 hours to drill 6 holes through the 1 1/4 inch rudder shaft. And a quarter can of Evaporated Milk....ARH....
Old 07-06-2018, 10:32 AM   #6
Sochin   Sochin is offline
Sochin's Avatar
ARH, yeah them crazy Norskies when THEY get stranded.....they do it really well too. How do I know? I'm born there
1983 Honda Xl600R
2016 Ducati Multistrada 1200S DVT
Old 07-06-2018, 01:32 PM   #7
He didn't get stranded, the original design was flawed and he was the designer , so I worked on it in the boatyard where it had spent the winter. Either the milk casian or butterfat in the milk is why it worked....ARH P.S. It was a patch job, it didn't really fix the problem, but he just "Wanted to get by for the season."
Old 07-07-2018, 08:30 PM   #8
Cravin01's Avatar
Update for those using this video for a aftermarket exhaust upgrade:
I found that the header pipe was leaking exhaust due to the flange pulling the pipe toward the side where I decided to just leave the bolt hole, I ended up notching the other side to allow it to pull down evenly without the binding and it seated up nice and even quieting down the bike a bit more.
Also the plastic fender melted in the video as you had seen, I was able to use the bolt and spacer supplied with the exhaust and added four more washers to get the clearance need and will be patching the melted area with a small piece of plate metal to support and protect the fender from this point forward.
I'll be sure to show a quick update and what was done in the next video.
Thanks for watching!
2017 Bashan Storm
Old 07-08-2018, 08:32 PM   #9
Cravin01's Avatar
Put the update on the exhaust in the vlog and went through rejetting the carb.
http://chinariders.net/showthread.ph...569#post285569
2017 Bashan Storm
Old 08-04-2018, 05:50 PM   #10
Cravin01's Avatar
New Carb finally came in and now its time to get running again, New vid on page 2 of link!
http://chinariders.net/showthread.ph...517#post287517
2017 Bashan Storm
Old 08-22-2018, 06:29 PM   #11
Cravin01's Avatar
The speedometer mod is complete! Vid is a little long but I didn't want to do 2 vidz on the same mod.
http://chinariders.net/showthread.php?t=21028&page=2
2017 Bashan Storm
