07-28-2018, 08:10 PM | #1 |
Is the 47T JTR269.47 sproket a direct swap?
https://www.ebay.com/itm/NEW-JT-REAR...LH_TitleDesc=0
Wondering if it's a direct swap, or are modifications, spacers and such necessary for fitment? Looking to get a tad bit more top end. TIA |
07-29-2018, 02:38 AM | #2 |
For the Hawks and most of the Bashan bikes, yes.
For the TT250, yes - but requires small spacers (about 5mm) and the sprocket installed with the recess facing out. This is due to the rear hub being a little different, with the sprockets bolting in place and the factory sprocket having a small offset to it. It helps to note what bike it is for in the post, or to simply add it to your signature. Otherwise you will get a very generic response.
07-29-2018, 10:09 PM | #3 |
what bike is this for ?
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
07-30-2018, 01:54 PM | #4 | |
I did my TT by installing some washers behind the sprocket that amount to the 5.5 mm that was suggested by CSC. They sell spacers with their 49T kit but don't sell them separately. I also had to sand off the powdercoat from the center hole for the sprocket to easily slip over the hub because it's a little too tight to slip over without being forced.
2016 CSC TT 250, 17/40 sprockets, JT 428 chain, Stock Keima carburetor with needle raised 1 notch and 115 main jet. Modified stock exhaust, Tachometer/Digital cluster upgrade. LED headlight, Superbrightleds 1157 Tail light bulb, Shinko 705's 90/90-21 and 120/80-18. |
08-05-2018, 12:05 AM | #5 |
