PCV - which type needed for Hawk?
From what I've read, it seems it's recommended to install a PCV on that hose coming out of the crankcase so that it can expunge air, but not suck air back in. I've checked Amazon and some auto parts store websites...what works best with the Hawk? Seems many PCV's are designed to thread into something and not for connecting a 1/4" hose on both ends. If someone could provide a link to what would work, that would be greatly appreciated!
Would something like this work? https://www.amazon.com/Omix-Ada-1740...ords=PCV+Valve
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks |
I just bought one for mine day before yesterday at Autozone. Just pull your breather hose and take it with you. I found they had an assortment of about 20 different pcv valves to choose from. Some bigger,some smaller. Some inline, some screw in, 90 degree, in-line etc.
Just take your hose to a big chain auto store and start matching up. Buy a few hose clamps to splice it in there |
#3 | |
If yer gonna spit oil, spit it on the chain!
Thanks for the tips guys. I bought a PCV valve (Durazone brand) from the auto parts store and fit the valve onto the stock breather tube coming out of the engine case, then bought a foot of 5/16" fuel hose to connect to the smaller outlet of the valve down to the chain. I zip tied everything to the frame and aligned the output hose right over the chain. To seal off the airbox, I plugged the crankcase inlet with silicone. Free chain oil if the crank decides to spit some oil (which it hasn't done yet). I figured it was better to just vent the crankcase out into the open instead of into the airbox where it could foul it up. Here are photos...
Stock hose from the crankcase to the PCV valve... ![]() In-line PCV valve... ![]() Output hose right over chain where it can lube it if the crank burps out any oil... ![]()
2018 RPS Hawk 250cc Mods so far: 1. Mikuni VM26 Carburetor w/#115 main jet 2. 17T/45T JT sprockets 3. JT 428 X-ring chain 4. Air box mod 5. Hawk Digital Cluster 6. Aftermarket IMS shift lever 7. Performance Aftermarket Exhaust 8. 295mm Nitrogen Gas Monoshock, 20W oil front forks Last edited by ChrisWNY; 08-04-2018 at 03:17 PM. |
Just curious here, is there a reason that we don't want to run the hose back to the carb inlet? I did that on my Rhino when I switched to the pod filter as the stock filter had a barb on it for this purpose. My grandson's 125 ATV came stock with a pod filter and is set up this way also.
#7 | |
If you are OCD about EPA/emissions, go ahead and route it back to the intake to complete the circle of life
"Think as you like... but this self proclaimed Professor is always right" - Buckshot ![]() "You never know what someone is hiding beneath their smile..." - NinjaTom - R.I.P. |
Well, i voted for routing all oil burping hoses to exit over MegaDans shoe, but I got
reprimanded .just sayin'. : )
2001 Mustang GT 2004 Sportster 2018 VADER 2020 Orion RXB250L Last edited by RedCrowRides; 08-05-2018 at 09:47 AM. |
#10 |
Isn't fresh air best for combustion though? I would think that exhaust emissions from the crank would be somewhat less efficient than fresh air in through the airbox. Or maybe it's just negligible as most the exhaust emissions go through the pipe and out the muffler.
#11 |
https://www.amazon.com/FV379-Positiv.../dp/B000C2ZJP2
I used this one. I used fuel hose on the skinny side under the original hose. |
#12 | |
Positive side to a "closed" system: Takes harmful vapors back into the intake and try to combust/heat them up enough to turn them into a less harmful vapor... lowering nasty emissions and the smog in cities... we get to prove Al Gore wrong, WWF gets their name back (WWE joke), polar bears get their ice to play on, hippies get to go hug more trees, unicorns and dragons exist, previously extinct animals come back to life... you get the idea ![]() Negative side to a "closed" system: Those harmful vapors over time can create varnish/gum/carbon/sludge build up in various places... Real easy to fix and inexpensive if you do it yourself, you just have to do what almost every automotive dealership asks you to do on your car every 10 or 15k miles and do a "Multi step Fuel and Intake System cleaning"... it takes about 5 minutes (MAX) to clean things out with a few types of "snake oils in a can", basically a little bit from one gets poured into the gas tank, pull the air filter/intake boot from the carb/throttle body and spray a few seconds worth of the other one and yobs done ![]() I have our PCV set up as a "closed system", the hose is routed back into the UNI Pod Filter and have had no issues (about 4k miles on the bike), but I'm that rare 1%er round here ![]()
#13 | |
#14 |
Had my air hose disconnect from my air box and rain got in my engine not much so I did like 4 oil changes to flush it out. Found this thread and found out it’s getting in through my hose from airbox to Engine. so I installed a pcv valve and used black rubber sealant to repair leak. So lady at autozone let me behind counter to find a fit just wanted to share it’s for a Honda 94-06.
