Old 08-12-2018, 01:11 PM   #1
rterhark   rterhark is offline
zhejiang lingyu 150 scooter
ii have a zhejiang lingyu 150 scooter, i purchased a 24 mm carburetor from motopartsmax.com .this carb has all the same measurements .on the original the slide diaphragm melted. the new carb has a vacuum pump on the right side mine doesn't. the original one has a hose connector tube at the base of carb on intake side . can this be adapted to work on this scooter?
new carb stamped pd24j - kie ve180108a
original stamped pdj24j lt2800000 vekld 19
Old 08-12-2018, 05:44 PM   #2
Gh426   Gh426 is offline
stuff should NOT melt, is it near the stock pipe with a catalytic perverter on it? So don't go melting a 2nd one.
g
Old 08-14-2018, 12:16 PM   #3
did not melt from heat more of a chemical reaction. my main question was will kei hin carb adapt to application
Old 08-15-2018, 10:48 AM   #4
Please show us pics of the old and new carb.
Old 08-16-2018, 10:39 AM   #5
carburator
trying to send pictures. not working can you give me a valid e mail address
Old 08-16-2018, 11:16 AM   #6
Here's an easy way to post pics: http://www.chinariders.net/showthread.php?t=14422
Old 08-22-2018, 09:55 AM   #7
Old 08-22-2018, 11:31 AM   #8
tortoise   tortoise is offline
Research GY6 150 air-cut valve.
50cc carb describes the extra metal tube as "charcoal canister hook-up".
Old 08-22-2018, 11:38 AM   #9
I would definitely use the Keihin; it's a superior design. Notice that it has an exposed pilot mixture screw, whereas the stock carb is capped in that spot.
Just route the overflow hose of the new carb towards the ground. You must have a vacuum nipple on the intake tube; just connect hose that's on the new carb tee to that. The remaining nipple that is on the tee connects to your fuel pump.
Please let us know the result.
Old 10-28-2018, 01:03 PM   #10
Thumbs Up carburator
thank you for your advise! the scooter runs great with the keihin carb
